Solved uddeIM missing?
14 years 3 months ago - 14 years 3 months ago #130448 by Zuiq
uddeIM missing? was created by Zuiq
I've just upgraded from K 1.7 to 2.0.1, It seems to have installed perfectly, and i can find the plugin for uddeIM, but we can't find the "private messages" link on the forum! It used to be where the "announcements" link is now (as seen on this forum). I can't seem to figure out how to add it to a menu (as there is no menu item type for it) and i can't find any setting to enable it.
Is anyone able to tell me how to get it working..?
Last edit: 14 years 3 months ago by Zuiq.
14 years 3 months ago #130452 by Jiminimonka
Replied by Jiminimonka on topic uddeIM missing?
It is almost impossible to help any user when they ask a question but dont supply any information. Please read the posting guide and add your Kunena Configuration Keport.
Have you re-installed the latest version of uddeIM and do you have the Kunena uddeIM plugin enabled?
Please read the FAQ.
Only one question per topic.
14 years 3 months ago - 14 years 3 months ago #130455 by Zuiq
Replied by Zuiq on topic uddeIM missing?
I need to reinstall UddeIM, even though it comes packaged with K2.0.1?
Disregard the kr_rank, that is something one of our coders is working on.
Database collation check: wasp_kunena_kr_rank_groups have wrong collation of type latin1_swedish_ci on field group_title wasp_kunena_kr_ranks have wrong collation of type latin1_swedish_ci on field rank_title wasp_kunena_kr_ranks have wrong collation of type latin1_swedish_ci on field rank_image
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 128M
Joomla default template details : yoo_catalyst | author: YOOtheme | version: 1.0.2 | creationdate: December 2011
Kunena default template details : nts_kminigame | author: 9ThemeStore | version: 1.7.0 | creationdate: 2011-05-07
Plugins: None
Modules: Kunena Search 2.0.1
14 years 3 months ago - 14 years 3 months ago #130457 by Jiminimonka
uddeIM does not come with Kunena 2.0.1, it is a seperate Joomla product. Kunena has plugins to support uddeIM, but it still needs to be downloaded and installed from the uddeIM website .
Last edit: 14 years 3 months ago by Jiminimonka.
14 years 3 months ago #130458 by Zuiq
Oh i guess that's what confused me then, as i thought it came packaged with 2.0.1, as there wasn't a plugin with 1.7, well anyway, thanks for replying :)
14 years 3 months ago #130459 by Jiminimonka
No problem. You should disable the Kunena integration plugins that you are not using, like JomSocial, Community Builder etc.
