Solved Problem with the privileges
14 years 4 months ago - 14 years 4 months ago #128507 by kenzo
Hello!
Yesterday I upgraded from 1.7.2 to Kunena 2.0
Everything works but ...
Even though I'm super-administrator does not see the buttons "new topic", "quota" and more ...
If I try to create a new thread I get the following message:
You are not allowed to start a new thread!
As if I had the privilege but is Joomla! Kunena is that okay ... it seems.
Can anyone help me?
Below is my configuration.
Thanks to all!
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 64M | Max file upload: 25M
Joomla default template details : rt_infuse_j15 | author: RocketTheme, LLC | version: 1.5.6 | creationdate: August 17, 2010
Third-party components: UddeIM 2.8
Plugins: Content - Kunena Discuss 2.0.1
Modules: Kunena Latest 2.0.1 | Kunena Login 2.0.1
Last edit: 14 years 4 months ago by kenzo.
14 years 4 months ago - 14 years 4 months ago #128508 by kenzo
Replied by kenzo on topic Problem with the privileges
It could be the template? :dry:
Update:
No change ... I'm using the template Blue Eagle - version 2.0.1
14 years 4 months ago #128518 by kenzo
OMG I just got confirmation that as a user you can post and respond calmly. So I'm the only (administrator) not to post ...
14 years 4 months ago #128560 by sozzled
Replied by sozzled on topic Problem with the privileges
I have not seen before the message "You are not allowed to start a new thread!". This is a new one for me (especially since I though we had changed all references in Kunena that speak of "threads" to use the preferred term "topic"). Maybe this is something to do with the translation?
Have you looked at Only viable to logged in users and does this help you?
The problem could be caused by the way you have set up the categories in which you want to post. Maybe you have disabled administrator access?
14 years 4 months ago #128578 by kenzo
I'm sorry. It 'my fault translation from Italian into English.
Looking at the database I noticed that the table 'jos_kunena_users', field 'group_id' my account has value '1' as all other users. Is this correct?
14 years 4 months ago #128639 by kenzo
The strange thing is that I can safely delete, moderate, block.
I do NOT see the buttons 'quick replay', 'replay' and 'quote' :(
Time to create page: 0.145 seconds
