Solved change legend order
I would like to chnage it from default
Site Administrator, Global Moderator, Moderator, Banned, User, Guest
to
Site Administrator, Global Moderator, Moderator, User, Guest, Banned
Appreciate any help.
the only way is to hack kunena core file. Do you want this?
rich wrote: Go to "components/com_kunena/template/blue_eagle/html/common/whosonline.php" (line 52 - 54) and change the order of rows.
Thanks a lot, that worked.
- coder4life
- Kunena Contributor
- Thank you received: 50
