Important Badword2 - myth or it really works?
17 years 7 months ago #13032 by KoPoJIb
Dear Kunena Support
My team is launching official football festival website in town in few weeks. Unfortunately, we are experiencing serious problems with BADWORD COMPONENT. After 2 days of reading forums and applying BADWORD2 ( www.schoolastech.com/index.php?option=com_frontpage&Itemid=1 ), came to conclusion that it does not work. Actually, this thread reports about problems as well www.kunena.com/forum?func=view&catid=20&id=3446#3805 .
Main problems are :
-after successful installation of comBadWord2beta, when you go to component itself there is an error message saying that
Warning: file() [function.file]: Filename cannot be empty in /home/.../domains/.../public_html/administrator/components/com_badwords2/admin.badwords2.php on line 174
-Additionally, when you try to delete or add new badword, it says config file is protected. When I go to server to chane permissions of the file, it does not allow me because file has server permissions.
We are very tired and a bit disappointed. However, we believe that if there is a such filtering plugin that it should work. How about your forum on kunena.com? do you use any filtering components?
I would like kindly to ask whether you could assist us in this as we are expecting high volumes of visitors from different countries and we need to keep a good image of our favourite Kunena forum.
Thank you very much. We hope that this problem shall be resolved soon.
Regards,
Alex
17 years 7 months ago - 17 years 7 months ago #13110 by sozzled
I experimented with Badword2. It's probably a myth. See also bad words component?
I don't think this is a support problem for Kunena. It's just something left over from the old Fireboard days.
Last edit: 17 years 7 months ago by sozzled. Reason: not a support problem
17 years 7 months ago #13124 by grumblemarc
The developer of the extension would have to update it for use with Kunena. Just because Kunena integrates with it does not make it a Kunena problem when it doesn't work. Anyone know if this extension is still being developed? And if so will they make in compatible?
17 years 7 months ago #13142 by KoPoJIb
Guys, thanks for your comments. But I believe if Kunena possess itself as leading forum in Joomla and I see it is!!!!! then such simple feature should be resolved. It is not because only me needed. It is because badword filtering goes as a standard feature in most forums. I would like to suggest raise this topic with developers! Can somebody do this?
The main problem I see is that official and respected websites may not be willing to use it for obvious reasons. I think filtering badwords is a critical feature!
17 years 7 months ago #13143 by sozzled
Agreed. What, I believe GM is saying is that it's not within scope for the Kunena development team to develop a word filtering component. If no-one else is prepared to develop a word filtering component that will easily slot-into Kunena then that's the way the cookie crumbles, I guess.
17 years 7 months ago - 17 years 7 months ago #13182 by Matias
We will soon remove bad words integration from Kunena.
We are also looking for other solutions: all proposals are welcome!
If you know a good word filtering component for Joomla! 1.5, please let us know.
Last edit: 17 years 7 months ago by Matias.
Time to create page: 0.150 seconds
