Question Kunena and jAwards Integration
15 years 5 months ago #98210 by BoardBoss
Greetings all - I am posting in the general talk forum because I have searched these forums, and Googled many other sites, although I have thus far been unsuccessful in my quest for an answer to my question. I have found posts or sites that suggest that jAwards will integrate with Kunena with a hack; however, I cannot confirm that is with the latest versions.
My environment is Joomla 1.5.23, Kunena 1.6.4 and jAwards 1.1. I would appreciate an answer to he question: has anyone successfully integrated jAwards 1.1 into Kunena 1.6.4? If so, I would appreciate a reply with how, or a link to where this is detailed. Thanks in advance!
15 years 5 months ago #98221 by xillibit
I never heard something about jawards integration into Kunena, but the jawards components hasn't been updated since a bit more than an year, so...
15 years 5 months ago #98257 by BoardBoss
Thank you for the reply, xillibit. I understand what you mean about the last update for jAwards being very old; however, after reading this thread: www.kunena.org/forum/9-extensions-module...ds?limit=10&start=20 it made me wonder.
15 years 5 months ago #98397 by legu
humm, i dont think so...
15 years 5 months ago - 15 years 5 months ago #98497 by Lodder
Yes it does work. I have tested it on my website blackpanthergaming.com using Kunena 1.6.4 and the latest version of Jawards. The coding I have used will show 10 medals probaby about 5 per line, depending on the width of the profile info. This is of course editable. ;)
Put it in /components/com_kunena/template/default/view/profile.vertical.php on line 81 after:
<?php echo $this->profile->profileIcon('email'); ?>
</li>
<?php // Hack for jAwards integration, displays some medals of the user for Kunena 1.6 $number_medals = 10; // number of medals to show $query = "SELECT b.image, b.name" . "\n FROM #__jawards_awards AS a" . "\n LEFT JOIN #__jawards_medals AS b ON b.id = a.award" . "\n WHERE a.userid=". $this->profile->userid . "\n ORDER BY RAND() LIMIT ".$number_medals; $database = &JFactory::getDbo(); $database->setQuery( $query ); $medals = $database->loadObjectList(); // URL links to the jAwards-Tab for Community Builder which displays all // medals of the user - change to another URL of needed $awards_url=JRoute::_('index.php?option=com_comprofiler&task=userProfile&user='.$this->profile->userid."&tab=getawardstab"); // CSS-class "ja_medals" allows individual styling of medal images and // container. "nobr" keeps the medals from breaking apart, display them // in one row. $msg_jawards = "<div class=\"ja_medals\"><nobr>"; foreach ($medals as $med){ $msg_jawards.= "<a href=\"$awards_url\" title=\"$med->name\">" . "<img style='border:0px;padding:0px;' src=\"".KUNENA_JLIVEURL."/images/medals/".$med->image ."\" alt=\"".$med->name."\" />" . "</a>"; } $msg_jawards.="</nobr></div>"; unset($medals); echo $msg_jawards; ?>
Last edit: 15 years 5 months ago by Lodder.
15 years 3 months ago #102864 by Lodder
also works with Kunena 1.6.5 ;)
