Kunena 7.0.8 Released
Sticky Kunena 7.0.8 maintenance release for Joomla! 5.4, 6.0 and 6.1
1 month 20 hours ago #235138 by xillibit
Introduction:
The Kunena team is thrilled to announce the eighth maintenance...
Introduction:
The Kunena team is thrilled to announce the eighth maintenance release of Kunena 7.0, a native Joomla extension for Joomla! 5.4, Joomla 6.x and Joomla! 6.1. Kunena 7.0 works on Joomla! 6.0 natively without the needs of compat plugin.
For people which wants help for translations, Kunena 7.0 files can be translated on crowdin : crowdin kunena
Kunena 7.0 has been designed to work on Joomla! 5.4, 6.0 and 6.1, the minimal requirements are the followings :
  • Php 8.2.0
  • MariaDb 10.4 or MySQL 8.0.13
  • Bootstrap 5.x
The work done in Kunena 7.0 is mostly to update the code base:
  • Refactor all the code of plugin integration to be in Joomla! 6.0 by working with events and to drop the parts which was planned to be removed in this Joomla! version (thanks to ruud)
  • New: scheduled task purge trashbin (thanks to ruud)
  • Changes on the installer script to be able to work on Joomla! 6.0
  • Make user type on whoisonline widget as links to open the userlist filtered
  • Remove most of the deprecated code
  • Refactor captcha handling conform with Joomla! 5.x and 6.0
New features:
The Kunena system plugin check on registration and on login if the user is in stopforumspam database and prevent them to make these actions
The Kunena configuraion has been converted to be the same that others configurations page in the Joomla! way
Download:
Download K7.0.8 stable here: https://github.com/Kunena/Kunena-Forum/releases/tag/7.0.8
Donations
Any donations are needed for future support.
1 month 9 hours ago - 1 month 9 hours ago #235140 by Leen
Thank you,
But on the Kunena download site, the download won't start; there is an error in the download link
.7.0.8/pkg_kunena_v7.0.8_2026-08-05.zipp
one p too many
With kind regards
Leen
Last edit: 1 month 9 hours ago by Leen.
1 month 8 hours ago #235141 by xillibit
Thanks to have reported it, i have just fixed it
1 month 7 hours ago #235142 by Leen
but the live update on various websites with Extensions: Update gives a server time out after waiting. "504 Gateway Time-out"
if I install it manually, it works.
With kind regards
Leen
1 month 6 hours ago #235143 by xillibit
I have updated yerstayday a site with Joomla! updater i haven't encountered any issue
1 month 5 hours ago - 4 weeks 2 days ago #235144 by Leen
Okay, thank you.
Maybe my hoster (Vimexx) has changed something.
I will keep looking.
07-08-2026 Update
Everything is working properly again; the cause was that there were problems with the Vimexx provider.
With kind regards
Leen
Last edit: 4 weeks 2 days ago by Leen.
Time to create page: 0.262 seconds
