Kunena 7.0.8 Released
Question Kunena 7.0 Beta 2 Released for Joomla! 5.4 and 6.0
10 months 2 days ago #234083 by xillibit
Introduction:
The Kunena team is thrilled to announce the second public...
Introduction:
The Kunena team is thrilled to announce the second public beta release of Kunena 7.0, a native Joomla extension for Joomla! 5.4 and Joomla 6.x. This is a development release and should be only be used for testing; this version is not recommended for live websites at this stage. Kunena 7.0 works on Joomla! 6.0 natvely without the needs of compat plugin.
The purpose of this release is to encourage testing by downloading, installing and identifying any problems or shortcomings that people may discover. K 7.0.0 B2 is in testing phase and we are aware that people will discover defects. We encourage you to use the forum to report defects, as soon as they are discovered, so that the development team can work through the problems before the release of K 7.0 as a stable product. Reporting defects does not mean that the problems can or will be fixed. The Kunena team is looking forward to hearing your feedback on how well we have achieved our design goals.
Kunena 7.0 has been designed to work on Joomla! 5.4 and 6.0, the requirements are the followings :
  • Php 8.1.0
  • MariaDb 10.4 or MySQL 8.0.13
  • Bootstrap 5.x
The work done in Kunena 7.0 is mostly to update the code base:
  • Refactor all the code of plugin integration to be in Joomla! 6.0 by working with events and to drop the parts which was planned to be removed in this Joomla! version (thanks to ruud)
  • Changes on the installer script to be able to work on Joomla! 6.0
  • Make user type on whoisonline widget as links to open the userlist filtered
  • Remove most of the deprecated code
  • Refactor captcha handling conform with Joomla! 5.x and 6.0
New features:
The Kunena system plugin check on registration and on login if the user is in stopforumspam database and prevent them to make these actions
The Kunena configuraion has been converted to be the same that others configurations page in the Joomla! way
Download:
Download K7.0.0 Beta2 here: https://github.com/Kunena/Kunena-Forum/releases/tag/7.0-Beta2
Donations
Any donations are needed for future support.
10 months 2 days ago #234084 by Leen
When I try to install it, I get the following error:
Downgrading from version 7.0.0 to version 7.0.0-BETA2 is not allowed.
With kind regards
Leen
10 months 2 days ago #234085 by Leen
Okay, my mistake, I think.
I tried installing it over the Beta 1 version.
I installed Beta 2 via System, Installation, and Extensions.
It works fine in a clean Joomla 6.
With kind regards
Leen
10 months 2 days ago - 10 months 2 days ago #234086 by xillibit
I had made a mistake when i had done the beta1 release, it was considered as Kunena 7.0 stable instead of beta1. I had fixed it couple of days after in the release packages. In this case you can uninstall the actual version of Kunena 7.0 and install the beta2
Last edit: 10 months 2 days ago by xillibit.
10 months 2 days ago #234087 by Leen
Thank you.
Yes, I manually removed Kunena 7-beta1 from the test sites where it wasn't working because it wasn't working properly through Extensions: Manage.
But after that, installation wasn't a problem.
And on the test site with Kunena 6.4.6, it works right away.
With kind regards
Leen
10 months 1 day ago #234088 by rich
Check for updates:
It may also be necessary to modify or disable the “update.xml” file.
Time to create page: 0.235 seconds
