Idea blue_eagle_rtl for K2.0 الافتراضي blue_eagle_rtl قالب كونينا 2.0
13 years 10 months ago #136181 by xillibit
baazza wrote:
I have only changed the direction from LTR to RTL, and i rename the template to ( blue_eagle_rtl )
I do not modify anything else in the template
تحياتي
Best Regards
baazza
Where do you have changed the direction ?
13 years 10 months ago #136494 by baazza
تحياتي
Best Regards
baazza
CSS FILES
رضيت بالله ربا وبالاسلام دينا وبمحمد صلى الله عليه وسلم رسولا
testify & witness that there is no god worthy of being worshipped other than Allah and that Mohammad is His Messenger
13 years 9 months ago #137469 by xillibit
If you don't say which files you have modified and what you have changed, i won't be able to check your changes
13 years 9 months ago #138071 by mojtaba3000
Thanks a lot.
would you please tell me exactly what lines of files you changed?
I need to know that to change those lines for newer versions of the template.
13 years 8 months ago #139667 by ambaqasah
Many thanks. You have done a great job.
The following user(s) said Thank You: zazazi
13 years 7 months ago #140730 by zazazi
Thank you very much...always helpful..just one question: how to change the default font?
