Question JomSocial stops me posting messages to my Kunena forum
16 years 5 months ago - 16 years 5 months ago #44331 by softz
Hey everyone...
When a user wants to post a message after they click submit they are receive errors.
The message still post and comes up in the forum but the redirected page gives the following errors:
Warning: include_once(/home/content/24/5816924/html/components/com_community/libraries/userpoints.php) [function.include-once]: failed to open stream: No such file or directory in /home/content/24/5816924/html/components/com_kunena/template/default/post.php on line 309 Warning: include_once() [function.include]: Failed opening '/home/content/24/5816924/html/components/com_community/libraries/userpoints.php' for inclusion (include_path='.:/usr/local/php5/lib/php') in /home/content/24/5816924/html/components/com_kunena/template/default/post.php on line 309 Fatal error: Class 'CuserPoints' not found in /home/content/24/5816924/html/components/com_kunena/template/default/post.php on line 311
Any Help on this would be awesome
Jordan.
Last edit: 16 years 5 months ago by sozzled. Reason: Changed subject to improve search relevance
16 years 5 months ago #44332 by sozzled
You selected your forum to be integrated with AlphaUserPoints. Have you installed AlphaUserPoints?
What version of Kunena are you using. Please note that we only attend to support questions if you are using Kunena 1.5.11. Thank you. :)
16 years 5 months ago #44338 by softz
Thanks for the quick reply...
Im currently using 1.5.9 so i will upgrade to 11 now.
Also what are AlphaUserPoints?
Ill google it now :)
16 years 5 months ago #44343 by sozzled
When did these error messages begin to appear? Have they always occurred with Kunena on your website? I think you've changed your Kunena configuration settings to use AlphaUserPoints and you don't have that component installed on your website. If you don't have AlphaUserPoints - and you don't need AlphaUserPoints - then make sure your Kunena configuration settings to not try to integrate with AlphaUserPoints.
16 years 5 months ago #44348 by softz
Ummm im not sure when they started to be honest.
Ive upgrade to 1.5.11 now and have gone though my Config but under the Integration section its all set as:
Avatar using : Jomsocial
Profile: Jomsocial
PM's: Jomscoial
AlphaUserPoints
Enabled Points in profile: NO
Enabled Rules for Points: NO
So it is set to what it is meant to be?
Maybe i have eddited some wrong code or something i dont know?
16 years 5 months ago - 16 years 5 months ago #44350 by sozzled
softz wrote:
Maybe i have edited some wrong code or something i dont know?
Well, gee, I don't know how to help you with this. So, let's start at the very beginning.
What version of Joomla are you using? We know that you're using K 1.5.11, but what Kunena template are you using? JomSocial has been known to be the culprit with some Kunena problems, so what version of JomSocial are you using?
The problem, as you have described it, says that your trying to call an undefined PHP class CuserPoints. The traceback indicates the call passed through JomSocial. I'm beginning to suspect there's more to this problem than meets the eye. It doesn't appear to be Kunena-related.
If you've edited "code" what could you have changed?
On your clean test site (and, like all good website administrators you have one of those, don't you?) can you disable everything unconnected to Kunena and are you able to post messages?
Time to create page: 0.218 seconds
