Question Login Problems [SOLVED]
17 years 1 month ago - 16 years 10 months ago #31780 by NRyan115
I'm not sure how this could still be a problem.
I am using kunena and CB. I have disabled joomla registration (only registration through CB) and my login links all go through the CB login module.
However, the "login" and "register" links at the top of kunena still point to the default joomla pages. So, when you click Login in kunena it brings you to /user/login
and when you click register it comes back with an error page (because i turned off joomla registrations.
How can I get these two links in kunena to use the CB pages? I already have CB integration set in the kunena settings.
Last edit: 16 years 10 months ago by NRyan115.
17 years 1 month ago #31794 by xillibit
Replied by xillibit on topic Re:Login Problems
17 years 4 weeks ago #32183 by NRyan115
Replied by NRyan115 on topic Re:Login Problems
Ok, so you linked me to a thread that does not contain a solution. Does anyone know a solution?
17 years 1 week ago #33224 by Matias
Replied by Matias on topic Re:Login Problems
Yes, I think so. Check that your CB menu item is published for everyone, not just Registered.
17 years 6 days ago #33435 by NRyan115
There is no menu item. Community builder has a login module which on my site is in the top of the left position. It is set to public. My problems is with the login and register links inside the top of kunena pointing only to the joomla login page which is disabled.
Even though I have all community builder integration turned on, there is no place to change where the login and register links point. They seem to be hard coded to the joomla pages.
17 years 2 days ago #33683 by Matias
K1.5.8 will have fix for this (PM me to test early version).
