Question Additional Info icons with Community Builder
17 years 7 months ago #1359 by Andreaz
I think that this method www.bestofjoomla.com/component/option,co...mit,10/limitstart,0/ should be intergrated Kunena. And I saw some users have these icons in this forum and you are using Jomsocial. How's that?
17 years 7 months ago #1361 by fxstein
This work has not been done yet. It is on our planned list but will most likely not make it into 1.0.8
This integration is also not available for jomSocial at the moment. Only johnnydement has those showing, because he entered the data into the Kunena profile, before we installed jomSocial here.
Thx!
fxstein
17 years 7 months ago #1366 by Andreaz
OK thx for the answer. I have one more suggestion if you are planning this intergration in the futur. If it's possible, you could make that when user hovers on the icons the tooltip would display birthday, skype name and so on...
17 years 7 months ago #3308 by woonydanny
Just a quick question.... did this CB field integration make it into 1.08? or is this planned for 1.1?
cheers
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
17 years 7 months ago - 17 years 7 months ago #3339 by johnnydement
Basic CB integration will come with 1.0.8, it *should* do all the basic stuff our current jomsocial one dies, maybe a bit more :)
Last edit: 17 years 7 months ago by johnnydement.
17 years 6 months ago #8447 by baboon
i upgrade the last version of this mod to work with Kunena.
by the way i make also a specific plugin for create fields in CB, compatible withe the old fields, you can download it here :
www.joomlarulez.com/the-news/50-add-icon-cb-kunena.html
(need registration, choose Free members ;) )
or if you don't want to register use this code above :
############################################################## ## MOD Title: Additional Info icons with Community Builder ## MOD Author (Original For Fireboard 1.0.4, J!1.0 and J!1.5): rockandchelle http://www.bestofjoomla.com/component/option,com_kunena/func,fbprofile/task,showprf/Itemid,38/userid,5911/ ## MOD Author (Upgrade For Fireboard 1.0.5 RC2 and J!1.5): Baboon http://www.bestofjoomla.com/component/option,com_kunena/func,fbprofile/task,showprf/Itemid,38/userid,13316/ ## MOD Author (Upgrade For Kunena 1.0.8, CB 1.2 and J!1.5): JoomlaRuleZ http://www.joomlarulez.com ## MOD Description: Additional Info icons with Community Builder. ## MOD Version: 2.0 ## Installation Level: Intermediate ## Installation Time: 3 Minutes ## Files To Edit: 1 ## components/com_kunena/template/default/view.php ## Plugin to install in CB : 1 ## plug_addinfokuena_1.0.zip ############################################################## ## For Security Purposes, Please Check: http://www.joomlarulez.com ## For the latest version of this MOD. Downloading this MOD from other sites could cause malicious code to enter into your Kunena Forum. ############################################################## ## Author Notes: ## ## I have tested this MOD whit Kunena 1.0.8, CB 1.2, Joomla 1.5.8 and MySQL Database 5.0.27, Php 5.2.0 ## ## All the files join are already modifiate so you can copy them with no need to modifiate by yourself, ## but if you hard code your own file you have to do yourself the modification list above. ## ############################################################### ## IMPORTANT !!!!! Before Adding This MOD To Your Forum, You Should Back Up you DATABASE and All Files Related To This MOD ############################################################## ## Instructions Before modifiate file and upload: ## ## Install plug_addinfokuena_1.0.zip in CB ## ############################################################## ## This MOD is released under the GPL License. ## Intellectual Property is retained by the MOD Author(s) listed above ## Copyright: ©2009 Additional Info icons with Community Builder 2.0 ############################################################## ## MOD History: ## ## 2007-09-14 - Version 1.0 ## - First Version Public For Fireboard 1.0.4, J!1.0 and J!1.5 ## http://www.bestofjoomla.com/component/option,com_kunena/Itemid,38/func,view/id,21793/catid,58/limit,10/limitstart,0/#22689 ## 2008-12-24 - Version 1.1 ## - Version Public For Fireboard 1.0.5 RC2 and J! 1.5 ## http://www.bestofjoomla.com/component/option,com_kunena/Itemid,38/func,view/catid,58/id,21793/limit,10/limitstart,80/#63167 ## 2009-02-28 - Version 2.0 ## - Version Public For Kunena 1.0.8, CB 1.2 and J!1.5 ## http://www.joomlarulez.com ############################################################## ## IMPORTANT !!!!! Before Adding This MOD To Your Forum, You Should Back Up you DATABASE and All Files Related To This MOD ############################################################## # #-----[ Open ]------------------------------------------ # components/com_kunena/template/default_ex/view.php # #-----[ FIND near line 581]------------------------------------------ # $database->setQuery("SELECT a.*,b.name,b.username,b.gid FROM #__fb_users as a LEFT JOIN #__users as b on b.id=a.userid where a.userid='$fmessage->userid'"«»); $database->loadObject($userinfo); # #-----[ AFTER, ADD ]------------------------------------------ # // Start Mod by rockandchelle, baboon and JoomlaRuleZ to add community builder additional info if ($fbConfig->fb_profile == "cb" && $fbConfig->fb_profile && $fmessage->userid > 0) { unset($cbinfo); $database->setQuery("SELECT * FROM #__comprofiler where user_id='$fmessage->userid'"); $database->loadObject($cbinfo); if ($cbinfo->cb_gender != '') { $gender = $cbinfo->cb_gender; if (strcasecmp($gender,"male")==0) { $userinfo->gender = 1; } if (strcasecmp($gender,"female")==0) { $userinfo->gender = 2; } } if ($cbinfo->cb_personaltext != '') { $userinfo->personalText = $cbinfo->cb_personaltext; } if ($cbinfo->cb_icq != '') { $userinfo->ICQ = $cbinfo->cb_icq; } if ($cbinfo->cb_location != '') { $userinfo->location = $cbinfo->cb_location; } if ($cbinfo->cb_birthday != '') { $userinfo->birthdate = $cbinfo->cb_birthday; if (strcasecmp($cbinfo->cb_showage,"no") == 0 ) { $userinfo->birthdate = substr($cbinfo->cb_birthday,5,5); } } if ($cbinfo->cb_aim != '') { $userinfo->AIM = $cbinfo->cb_aim; } if ($cbinfo->cb_msn != '') { $userinfo->MSN = $cbinfo->cb_msn; } if ($cbinfo->cb_yim != '') { $userinfo->YIM = $cbinfo->cb_yim; } if ($cbinfo->cb_skype != '') { $userinfo->SKYPE = $cbinfo->cb_skype; } if ($cbinfo->cb_gtalk != '') { $userinfo->GTALK = $cbinfo->cb_gtalk; } if ($cbinfo->cb_websiteurl != '') { $userinfo->websiteurl = $cbinfo->cb_websiteurl; } if ($cbinfo->cb_websitename != '') { $userinfo->websitename = $cbinfo->cb_websitename; } } // Start Mod by rockandchelle, baboon and JoomlaRuleZ to add community builder additional info # #-----[ SAVE/CLOSE ALL FILES ]------------------------------------------ # # EoM
Time to create page: 0.249 seconds
