Question relative posts hack 0.1 beta
17 years 2 months ago - 17 years 2 months ago #27921 by guerilla
open view.php and find this:
<!-- F: List Actions Bottom -->
and paste this after:
<?php //similar posts hack by guerilla $percent=5; //similarity percentage, increase for sensitive matching. for example 10 is 10% match, 50 is 50% match, 100 is one o one $topics_only=0; //set 1 if you wanna show only topics, set 0 to show relative messages directly $limit = 5; //set number of relative messages if ($topics_only = 1) { $parent =" AND parent=0 "; } $query=("SELECT id, subject, name, time as zaman, catid, userid, MATCH(t1.message) AGAINST('$this_message->subject') as oran1, MATCH(t2.subject) AGAINST('$this_message->subject') as oran2 FROM #__fb_messages_text as t1 INNER JOIN #__fb_messages as t2 ON t2.id = t1.mesid WHERE (MATCH(t1.message) AGAINST('$this_message->subject') > $percent OR MATCH(t2.subject) AGAINST('$this_message->subject') > $percent) AND t2.id <>" . $this_message->id . $parent . " ORDER BY oran2 DESC, oran1 DESC LIMIT $limit;"); $sim_message=$kunena_db->setQuery($query); $sim_message = $kunena_db->loadObjectList(); echo mysql_error(); if (count($sim_message)> 0) { echo '<table class = "fb_blocktable' . $objCatInfo->class_sfx . '" id="fb_views" border = "0" cellspacing = "0" cellpadding = "5" width="100%"><thead><tr><th colspan="4"><div class = "fb_title_cover fbm">'; echo '<span class = "fb_title fbl"><b>Relative Posts</b></span></div></th></tr></thead>'; echo '<tr class = "fb_sth"><td class = "view-th ' . $boardclass . 'sectiontableheader"><b>Subject</b></td><td><b>Author</b></td><td align="right"><b>Date</b></td><td align="right"><b>Similarity</b></td></tr>'; foreach ($sim_message as $sonuc) { if ($sonuc->oran1 > $sonuc->oran2) { $oran = $sonuc->oran1; } else { $oran=$sonuc->oran2; } echo "<tr><td><a href=\"index.php?option=com_kunena&Itemid=" . KUNENA_COMPONENT_ITEMID . "&func=view&catid=" . $sonuc->catid . "&id=" . $sonuc->id. "\">" . $sonuc->subject . "</a></td>"; echo "<td>" . CKunenaLink::GetProfileLink($fbConfig, $sonuc->userid, $sonuc->name) . "</td>"; echo "<td align=\"right\">" . date(_DATETIME, $sonuc->zaman) . "</td>"; echo "<td align=\"right\">%" . (int)$oran . "</td></tr>"; } echo "</table>"; } //similar posts hack by gerilla ?>
finally open your phpmysqladmin and run this scripts:
ALTER TABLE jos_fb_messages ADD FULLTEXT(subject) ALTER TABLE jos_fb_messages_text ADD FULLTEXT(message)
thats all.
acknowledgements:
-to increase sensitivity of matching increase $percent=5; (for example $percent=10 ) value can between 0 to 100.
-$topics_only=0; //set this 1 if you wanna show only topics, set 0 to show all relatve posts directly (default is 0)
-$limit sets maximum number of relative posts showing, default is 5. you can set this what you want. 3, 8, 10 or 20 etc...
NOTE: DO NOT COPY CODES DIRECTLY FROM POST. PRESS QUOTE AND THEN COPY THE CODES FROM TEXT AREA.
Last edit: 17 years 2 months ago by guerilla.
17 years 2 months ago #27934 by gonzaunit
good job, but i have a problem.
Parse error: parse error in C:\xampplite\htdocs\caco\components\com_kunena\template\default_ex\view.php on line 1238
17 years 2 months ago #27964 by guerilla
did you copy post directly? kunena adds unwanted spaces to code. press quote button and copy the code from textarea.
by the way i forgot to tell, you must add fultext to search fields. open your phpmysqladmin and run this scripts:
17 years 2 months ago #27968 by gonzaunit
thanks great hack..
can see , this work.
[IMG
17 years 1 month ago - 17 years 1 month ago #31055 by FENIX
Sorry, but it doesn't work for me!
Please, help :(
When I enter any post (not topic) I see this - see the attachment
I have done everything correctly. I have made "tag hack" without any problems, so I know how to do that.
And I swithed on mistakes - nothing. I thought, I would see some syntax error at least. But nothing at all, so I do not really know where to look for that trouble to correct.
Last edit: 17 years 1 month ago by FENIX.
17 years 1 month ago #31069 by guerilla
did you copy code from post directly? you must first click quote and copy the code from text area.
