Question ItemIDs not respected, resulting in loss of module. Now with Steps posted to Confirm bug
17 years 1 month ago - 17 years 1 month ago #10629 by rogerdavis
www.mentalhealthpractitioners.com/index....unc=listcat&catid=84
Check the above link, then click on any forum. Notice that the RSS news module to the left is lost, because the ItemID changes.
Solution: Kunena should get the ItemID from the current URL.
Roger
Last edit: 17 years 1 month ago by rogerdavis.
17 years 1 month ago #10631 by eezz
I have found this issue with other components when re-installing/upgrading. Always I need to recreate the menu items and modules assigned to the component. I guess that I wouldn't expect the new forum upgrade to be any different...
17 years 1 month ago #10659 by rogerdavis
To my knowledge, it has never worked. To my knowledge, it's a bug. Can someone else confirm this bug, just so I know it's not me?
Roger
17 years 1 month ago #10681 by rogerdavis
I'd pay to have this fixed...how can I contact the developers?
17 years 1 month ago #10692 by eezz
The issue is with Joomla itself. If you install a new component, which is what you are doing with this upgrade, the old ItemID will still point to the new component, but the modules that were on it are 'orphaned'. I had this problem with another completely different component when upgrading to a new version. I notice on you site you have two menus each with different ID's one to the new one and one to the old... Joomla has nevr been good with ID's, although its waaay better than it was back in the 1.0.* days.
17 years 1 month ago #10819 by rogerdavis
No, this is a different issue. The forums at www.mentalhealthpractitioners.com/index....unc=listcat&catid=84 are simply a category of forums. You can link to a catgory of Forums. And when you do, each menu item gets its own Item ID. But................the links inside the forum itself still reflect the main forum link. The links inside the forum need to reflect the Item Id associated with the menu item that links to the cagegories.
As for losing the ItemID on upgrading...no that worked fine.
Time to create page: 0.352 seconds
