This is not a support forum for AlphaUserPoints or its related products. For AlphaUserPoints support you should visit AlphaPlug .
The information given in this category is intended to guide users who want to use AlphaUserPoints with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of AlphaUserPoints.
Question Rules not working
13 years 1 month ago #149571 by kenroga
Rules not working was created by kenroga
Hola,
Tengo instalado Joomla 3.x, AUP 1.9.x, Jomsocial 3.x y Kunena 3.x, El problema que tengo es que no funciona los puntos al crear temas o respuestas en el foro Kunena. Tengo las reglas activadas.
GT:
I have installed Joomla 3.x, 1.9.x AUP, JomSocial Kunena 3.x 3.x, The problem I have is that it does not work the points to create topics or replies Kunena forum. I have activated rules.
Regards.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 50M
Joomla default template details : ja_mitius | author: JoomlArt.com | version: 1.0.4 | creationdate: Unknown
Kunena default template details : JA Mitius | author: Kunena Team | version: 2.0.4 | creationdate: 2013-01-18
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Third-party components: AlphaUserPoints 1.9.2 | Jomsocial 3.0.2
Plugins: JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
13 years 1 month ago #149577 by xillibit
Replied by xillibit on topic Rules not working
Can-you please upgrade your Joomla! version to 3.1.5 version and Kunena version to 3.0.2.
13 years 1 month ago #149579 by kenroga
Replied by kenroga on topic Rules not working
Hola,
Acabo de actualizar ambos, y sigue sin funcionar.
GT:
I just upgraded both and still not working.
13 years 1 month ago #149583 by xillibit
You can read that : www.kunena.org/docs/Configure_AUP_to_work_with_Kunena
But i presume that the issue is because you are using activities from jomsocial, so sometimes it work for the first one and not for the second one
13 years 1 month ago #149591 by kenroga
Cual es el orden adecuado, o la configuración idónea para que funcione correctamente.
GT:
What is the proper order, or the ideal setting to work properly.
13 years 1 month ago #149619 by xillibit
You can disable activity in jomoscial plugin integration if you don't need it like, like that it will work with AUP
