Question Migrating from vBulletin to Kunena
14 years 11 months ago #110105
by JuJ
Migrating from vBulletin to Kunena was created by JuJ
Hi there,
I would like to migrate my vBulletin to Kunena. My actual forum is linked to Joomla (1.5) with jFusion.
Is there any migrator for this?
Thanks for your answer.
Best.
Best.
14 years 11 months ago #110106
by xillibit
Replied by xillibit on topic Re: Migrating from vBulletin to Kunena
The migrator component doesn't support actually migration from vbulettin, i can't say when the migrator will support vbuletin. Maybe you can migrate to phpbb3 and then to kunena...
14 years 11 months ago #110114
by JuJ
Replied by JuJ on topic Re: Migrating from vBulletin to Kunena
Thanks a lot, Xillibit, for your answer.
I'll try this and let you know.
Thanks again,
best.
Thanks again,
best.
14 years 11 months ago #110202
by JuJ
It was hell to migrate from vBulletin to phpBB3.
So I made the migration with SMF2, and it was a successful operation...
Thanks for your help and support.
Best.
Best.
14 years 9 months ago #114129
by janaf
Replied by janaf on topic Re: Migrating from vBulletin to Kunena
I am interested in how you did you do the SMF2 conversion. vB to SMF2 and then SMF2 to Kunena? Was it vB 3.X or 4.X ?
14 years 9 months ago - 14 years 9 months ago #114133
by fairwea1
Replied by fairwea1 on topic Re: Migrating from vBulletin to Kunena
You have to go vbulletin4 to smf2 to phpbb3 to kunena.
I attached the converters to this post. After converting vbulletin to smf2 I went into phpmyadmin to my smf2 tables, click on config, then edit method, change the auth from smf2 to vb3. That enables the vbulletin authentication plugin. Now you can login to smf2 with your old vbulletin passwords and run all of your maintenance to make sure smf2 displays properly.
This will convert pretty much everything except pm's.
Here's a before and after sample:
vbulletin
Kunena
vbulletin
Kunena
Last edit: 14 years 9 months ago by fairwea1.
The following user(s) said Thank You: janaf
Time to create page: 0.245 seconds
