Question Search Plugin does not work
15 years 11 months ago - 15 years 11 months ago #75825 by mibert
Hi there,
I am using Kunena 1.6.1 in a Joomla 1.5.22 Installation.
I tried to install the current search plugin plg_kunenasearch_v1.6.0-RC2_b94 in the Joomla backend and it seemed to be installed OK but as a matter of fact, its not working at all.
When trying to uninstall it, I get a message saying "Plugin Uninstall: Manifest File invalid or not found"
Is there any fix for this issue or does anybody have the same problem.
Thanks in advance for your advise.
Best regards
Michael
BTW: The search function of this forum also seems not to work for me. I tried to search for the terms "search plugin" but the result is an empty page. Here is the URL:
www.kunena.org/forum/advsearch?q=Search+...name=1&childforums=1
Last edit: 15 years 11 months ago by mibert.
15 years 11 months ago #75832 by xillibit
Which method do you using to install this plugin ?
15 years 11 months ago #75833 by mibert
I used the normal Joomla backend installation.
15 years 11 months ago #75837 by xillibit
Yes, by putting the zip file or using directory method ?
15 years 11 months ago #75838 by mibert
I used the ZIP file method
15 years 11 months ago #75844 by xillibit
Do you have if there is a xml file in the archive ?
Maybe the archive is corrupted try to re-download it with firefox ?
