Question ERROR: mod_kunenalatest: Kunena 1.6.0-RC2 (or later) is not installed on your system!
  • Azure
  • Azure's Avatar Topic Author
  • Offline
  • Senior Member
  • Senior Member
  • There can only be one forum,,,,
15 years 11 months ago - 15 years 11 months ago #75404 by Azure
I have an error message with the Kunena Latest post module which is saying that I don't have a Kunena 1.6.0-RC2 or later version installed on my system. In actual fact, this is what I have installed :
Kunena 1.6.1 | 2010-11-06 | 3858 [ Timu ] - I believe this is the very latest Kunena version, so can't figure out what's going wrong with the module.
Further info:
PHP Built on: Linux hm1.hostingmetro.com 2.6.18-294.8.1.el5.lve0.7.32PAE #1 SMP Fri Jul 23 15:24:15 EEST 2010 i686
Database Version: 5.0.91-community
Database Collation: latin1_swedish_ci
PHP Version: 5.2.14
Web Server: Apache
Web Server to PHP interface: cgi
Joomla! 1.5.22 Stable [ senu takaa ama woi ] 04-November-2010 18:00 GMT
"Do or do not, there is no try..."
Last edit: 15 years 11 months ago by Azure.
  • Azure
  • Offline
  • Senior Member
  • Senior Member
15 years 10 months ago #78366 by Azure
Fixed.
15 years 10 months ago #79274 by twingo
@Azure
I have the same Error Message - can you tell me how you fixed this ?
Greetings
twingo
15 years 10 months ago #79276 by Mortti
Have you tried latest Kunena 1.6.2 component and it's latest Kunena Latest module (com_kunena_v1.6.2_b3894_2010-12-29.zip & mod_kunenalatest_v1.6.2_b273_2010-12-29.zip) ?
Those both and all others can be found here: joomlacode.org/gf/project/kunena/frs/
15 years 10 months ago #80069 by global21
I have exactly the same problem can you tell me how you fixed this, i'm lost.
Regards,
stefan.
15 years 10 months ago #80091 by xillibit
Are-you using latest kunena 1.6.2 version and latest version 1.6.2 of the module ?
The following user(s) said Thank You: global21
