Important Kunena Discuss not functioning
15 years 9 months ago - 15 years 9 months ago #84998 by bleroy
I'm a noobie. I installed the Kunena Discuss plugin over kunena core and it's not working. There is nothing to click on to post an article comment. I can't find any documentation on the plugin, so I'm at a loss.
System
Joomla 1.5.22
Kunena core 1.6.3
Kunena Discuss plugin 1.6.2 (enabled)
Community Builder 1.3.1
Here is the message log I get. It appears at the top of an article.
[KunenaDiscuss debug: Created #__kunenadiscuss cross reference table. ]
[KunenaDiscuss debug: Constructor called in com_content ]
[KunenaDiscuss debug: onPrepareContent.Deny: There is no default Kunena category ]
[KunenaDiscuss debug: onPrepareContent: Allowing only Custom Topics ]
[KunenaDiscuss debug: onPrepareContent: Article 67 ]
[KunenaDiscuss debug: onPrepareContent: Searched for {kunena_discuss:#}: Custom Topic not found. ]
The following configuration details are from the Kunena component:
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 96M | Max file upload: 24M
Joomla default template details : sgtv6_f | author: | version: 1.0 | creationdate: 2011-02-06
Kunena default template details : Integrity Pro Kunena 1.6 Template | author: TemplateKunena Team | version: 1.6.2 | creationdate: 2011-01-24
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Thanks in advance for the help
Last edit: 15 years 9 months ago by bleroy. Reason: Additional information
15 years 9 months ago - 15 years 9 months ago #85210 by wgdejonge
Same problem here.... but not a noobie :P
Plugin installed, activated, but nothing happens...
Last edit: 15 years 9 months ago by wgdejonge.
15 years 9 months ago #85220 by xillibit
You have something wrong in your plugin configuration, look here : www.kunena.org/forum/178-kunena-discuss-...cussbot-instructions
15 years 9 months ago - 15 years 9 months ago #85356 by Athanor
Hi all!
That post is 5 months old...
I have installed Kunena discuss 1.6.2 on Joomla 1.6 but the discuss plugin has not the parameter section (there is only the details section) and articles don't show any link to the forums...
Where am I wrong?
Thank you
Edit: I have read this post only now: www.kunena.org/forum/178-kunena-discuss-...iscuss-and-joomla-16
I hope you can test soon the discuss plugin because it is very important to me and many other!
Thank you again
Last edit: 15 years 9 months ago by Athanor.
15 years 9 months ago #85442 by bleroy
Ok..configured the plugin in accordance with instructions, but nothing shows up on the page. Looking at logs, it appears to be working, but nothing appears.
Screenshot is current config.....
15 years 9 months ago #85448 by xillibit
Athanor wrote: Hi all!
Where am I wrong?
Thank you
Thank you again
Are-you using Joomla! 1.6 ?
for the moment, this plugin hasn't tested under this joomla version
Time to create page: 0.163 seconds
