Idea Modules and Plugins to be upgraded to 1.6.2
15 years 11 months ago - 15 years 10 months ago #69056 by fxstein
Now that Kunena 1.6.1 has been released, we will focus on the modules and plugins. Over the next hours and days we will release 1.6.1 versions of all our extensions.
EDIT: We are skipping 1.6.1 for the plugins and modules and are going straight to 1.6.2 as it requires some changes to Kunena itself that are shipping with 1.6.2.
Last edit: 15 years 10 months ago by fxstein.
The following user(s) said Thank You: Admata
15 years 11 months ago #69061 by vatoloco
This is good news. I am eagerly waiting for the final discussbot-plugin and hope that you have found the reason why the latest test-releases of the plugin produced hundreds of identical threads. Thanks for all your hard works in advance!
15 years 11 months ago #69064 by fxstein
vatoloco wrote: This is good news. I am eagerly waiting for the final discussbot-plugin and hope that you have found the reason why the latest test-releases of the plugin produced hundreds of identical threads. Thanks for all your hard works in advance!
Glad you are posting up. That is the one thing we have not been able to reproduce. We have installed the lastest buil don various sites, never seeing hundreds of threads.
Could it be that you had a pre 1.6 version on your system? Wonder it there is something messed up with the data model.
15 years 11 months ago - 15 years 11 months ago #69072 by vatoloco
Thanx for the fast answer! A stated in the following link user Sebkun also had a similar problem:
www.kunena.org/forum/15-testers/68566-bu...hread-on-1st-comment
With plg_kunenadiscuss_v1.6.0-RC2_b176_2010-08-31.zip I didn't have that problem but I have to add that on plg_kunenadiscuss_v1.6.0-RC2_b176_2010-08-31.zip I didn't use {kunena_discuss:0} !!!
This is my situation: I have Joomfish installed and my main language is german and second language is english. With plg_kunenadiscuss_v1.6.0-RC2_b176_2010-08-31.zip I got this error without using {kunena_discuss:0}:
Error -post-: Duplicate. Identical message has been ignored.
In detail this means for e.g.: a news article in RC2 was opened up in german language and correctly mapped into the forum. With correctly I mean that it was only created 1x. But now if same news article was opened up in english language then I got the error stated above. I started also a request for joomfish support here cause I don't want my german articles mapped to the forum as the forum is only in english language:
www.kunena.org/forum/178-kunena-discuss-...botspecifiy-language
So I began to use {kunena_discus:0} for german news articles and didn't add this parameter to the english joomfish translation as I wanted the plugin to autocreate only the english articles in the forum. So I think this might be the reason for the problem since RC2! I didn't use {kunena_discuss:0} in RC2! I began to use {kunena_discuss:0} since about 1week in RC3 test-releases to avoid the Duplicate-post message and force only english articles to be autocreated in forum category. But since then I am having the issue with hundreds of identical thread-creations...
So I think I have to avoid that {kunena_discuss:0] and need either full Joomfish-Support (something like an option in plugin params to set language code de_De / en_GB) or something that disactivates the plugin on "ww.blablamydomain.com/de/" and enables it for "ww.blablamydomain.com/en/".
Maybe this detailed description can help you to solve my problem.
To answer your question if I had a pre 1.6 version on my system: No I didn't! I started to use Kunena on my site with 1.6.0.
Last edit: 15 years 11 months ago by vatoloco.
15 years 11 months ago #69075 by fxstein
Ah - I see. This issue might be related to joomfish. We have not tested our modules and plugins with joomfish. Any sort of compatibility work with joomfish, will most likely not make it into the 1.6.1 release.
15 years 11 months ago #69115 by vatoloco
Ok! I will do now a complete backup of my site + db with Akeeba-Backup and then set up a new XAMPP nad test it again with 1.6.1 on my local machine and then let you know my result...
Thanx again for taking time to help me!
