This category is for the plugin developed, endorsed, maintained and supported by the Kunena project team. The topics in this category only relate to the plugin developed for K 1.6 and later versions.
Bug Making all posts appear in article's page, no links back to forum
14 years 10 months ago #111138 by flegascoin
Hi all,
I have installed Kunena + Discuss version 1.7, and I would like to keep all posts within the commented articles, without linking back to the forum ( ie. no "Read more" taking the users to the forum's page).
Is there a way to do that ? I played around with the options but haven't found one so far ...
Many thanks,
Fab
14 years 10 months ago #111160 by Matias
You need to edit the template a bit to hide the links from it. Should be doable.
14 years 10 months ago #111163 by flegascoin
Thanks Matias, appreciate your quick reply very much.
I will do that. Cheers, Fabrice.
14 years 3 months ago - 14 years 3 months ago #126587 by tricon
I have a similar (same idea but in reverse) question. I would like to remove/hide the 'Read more...' link that appears in the forum's first post. It doesn't seem to make any difference what the 'Content in First Post' setting is set to, the 'Read more...' link always appears.
Thanks!
Last edit: 14 years 3 months ago by tricon.
14 years 3 months ago #126589 by sozzled
I'm sorry but I don't understand your question. Could you please post your configuration report and provide us with a screen capture that illustrates the problem that you would like help with. Thank you.
14 years 3 months ago - 14 years 3 months ago #126808 by tricon
I was just wondering if it is possible to hide the highlighted area.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : rt_dominion | author: RocketTheme, LLC | version: 1.6.3 | creationdate: June 20, 2012
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.7.2
Last edit: 14 years 3 months ago by sozzled. Reason: "un-spoiler" configuration report
Time to create page: 0.157 seconds
