Question Upgrade 1.6.1 to 1.6.2
15 years 3 months ago #79088 by Shimei
Can anyone make the upgrade instructions easier for 1.6.1 to 1.6.2? Do I need to uninstall the 1.6.1 first, and if so will I lose all forum posts? Is there an upgrade feature in 1.6.1 I'm overlooking?
15 years 3 months ago #79089 by 810
Replied by 810 on topic Re: Upgrade 1.6.1 to 1.6.2
You don't have to uninstall kunena. just install it using joomla installer. No loose off posts. Just click on update.
Regards 810
The following user(s) said Thank You: Shimei
15 years 3 months ago #79095 by Shimei
Replied by Shimei on topic Re: Upgrade 1.6.1 to 1.6.2
That was made very easy. The upgrade went without a glitch. Thank you!
15 years 3 months ago - 15 years 3 months ago #79202 by sozzled
Replied by sozzled on topic Re: Upgrade 1.6.1 to 1.6.2
I'm pleased to hear that the upgrade went well.
For the many users who ask this similar question, upgrading within the same version of Kunena is straightforward case using the Joomla Extension Manager and installing Kunena with a different installation kit. So if you were, for example going from K 1.5.8 to K 1.5.13 you would simply install Kunena using the K 1.5.13 installation kit. Likewise, if you are going from K 1.6.1 to K 1.6.2 you would use the same approach. This is one of the really good features about Kunena. You don't need to uninstall Kunena in order to upgrade Kunena!
But, with K 1.6 there's an added benefit. You can upgrade and downgrade using the K 1.6 installer! This means that you can easily upgrade from, say, K 1.5.13 to K 1.6.2 and you can go back to K 1.5.13 if the installation was unsuccessful! :)
Of course there are a couple of small catches to this general statement. The main catch is this: if you have made any changes to the standard, core Kunena source code as distributed with the installation then you will lose those changes when you upgrade. But this means that if you add anything later, you won't lose those additions and, with K 1.6, those additions should also work when you upgrade. :)
Last edit: 15 years 3 months ago by sozzled.
The following user(s) said Thank You: marco168
15 years 3 months ago #79387 by jpsumon.niit
My site forum is working on kunena 1.6.1. Now I want to update to 1.6.2
Please let me How to update kunena 1.6.1 to 1.6.2 ?
15 years 3 months ago #79391 by Yrezvani
furthermore 1.6.0 to 1.6.2, please?;)
Time to create page: 0.296 seconds
