Question I want to upgrade to K 1.6 RC2. Can I copy and use my K 1.5 template CSS?
I use the default template, but i have edited the color scheme. When i upgrade will i be able to copy the css over to 1.6 to keep my color scheme?
The answer is no.thetoast wrote: I use the default template, but i have edited the color scheme. When i upgrade will i be able to copy the css over to 1.6 to keep my color scheme?
See docs.kunena.com/index.php/Kunena_1.6.0rc...rty_Kunena_Templates
Which the old version of Kunena you could move the avatar/profile info part of the posting body to the left instead of the right.
Can this still be done? Is the way to change that still the same? If not where can i find this info.
When i use the search i just get blank grey boxes with no text.
thetoast wrote: I have been searching th support and general questions for 1.6RC2 but can't find any info on this.
backend/kunena/template manager/
click on template you using and select profilebx position you require and save
easy and simple as that no hacking required..
