Important Upgrade kunena 1.6.3 always error
15 years 1 month ago - 15 years 1 month ago #91658 by Ngablu
i'm sory for my english, i'm use google translate.
I have more than 3 times Kunena 1.6.3 upgrade on my joomla, online and offline. but always error and my last upgrade on localhost, my joomla site could not be accessed, and the message ..
Fatal error: Can not redeclare class smile in C: \ xampp \ htdocs \ ngablu \ components \ com_kunena \ template \ default \ smile.class.php on line 31
the message was the same as what I'm trying to websites that are already online ... what should I do?
Last edit: 15 years 1 month ago by Ngablu.
15 years 1 month ago #91670 by xillibit
Is it the complete error message ?
I had seen in the past a conflict with others componentes/modules, a list of your components/modules/plugins that you are using should help
15 years 1 month ago - 15 years 1 month ago #91684 by Ngablu
Thanks for reply xillibit...
when I click preview in backend joomla, then display that appears on my website frontend only that,
nothing else .... I will review my joomla extensions, then I will report it on your ...
15 years 1 month ago #91687 by xillibit
Can-you put here please your Kunena configuration setting ?
15 years 1 month ago #91709 by Ngablu
xillibit wrote: Can-you put here please your Kunena configuration setting ?
if you mean setting on my Kunena in my joomla backend ..
if it is, I attach a screenshot ...
or word..
[attachment:11]SETTING MY KUNENA.doc[/attachment]
15 years 1 month ago #91711 by xillibit
