Question Kunena Control Panel Blank?
15 years 11 months ago #78014 by snilloconator
I have successfully upgraded several Agora sites to Kunena and only on my own personal site have I run into this problem. The upgrade went well but for some reason when clicking on the Kunena Forum tab or the Kunena Control Panel in the backend the page is blank. However if I hover over the Kunena Forum in menu and select any of the sub-directories like config, cat manager, etc.. the pages display fine. I also can manipulate the forums to my likings.
I have checked my error logs with only a few that seem irrelevant and have also turned of any plugins that may be conflicting with the upgrade (although I don't think plugins affect the backend).
I searched the forums and do apologize if this has been posted. I did find threads involving blank pages but not as unique as mine. :)
15 years 11 months ago #78159 by xillibit
Do you have tried to enable debug mode in Joomla configuration panel, to see if there are some errors messages which are displayed.
15 years 11 months ago #78239 by snilloconator
15 years 11 months ago #78240 by snilloconator
15 years 11 months ago #78277 by xillibit
Try to enable debug mode in Kunena configuration panel and try to disable the kunena update check.
15 years 10 months ago #79096 by snilloconator
xillibit wrote: Try to enable debug mode in Kunena configuration panel and try to disable the kunena update check.
This worked! Thank You xilibit
Time to create page: 0.151 seconds
