To get started please see
K 1.6 & K 1.7 Installation Guide
in our
Documentation Wiki
Question Install issues on joomla 1.5.20 upgrade from Kunena 1.5.12
16 years 4 days ago #63363
by eloshy
Install issues on joomla 1.5.20 upgrade from Kunena 1.5.12 was created by eloshy
I tried to upgrade to the new 1.6 last night and ran into some issues.
I did make a backup of my site, so I just kickstarted that to get my site working, but wanted to see what happened.
I went through the process and when asked if I wanted to import my database from 1.5.12 I checked yes. My admin area worked fine, but my front page only my header and logo would show.
I did some investing on the forum first and uninstalled the recent post mod and AutoTweet NG Kunena-Extension and turned off legacy.
I then used the roll back feature in Kunena and intalled 1.5.12 hoping my site would be back to normal. It was not.
So I decided to try to reinstall 1.6 hoping it would work then, but still the same issue.
So I then decided to restore my backup and make a post and what I can do to get this to work.
So any ideas on what the issue is?
16 years 4 days ago #63368
by xillibit
Replied by xillibit on topic Re: Install issues on joomla 1.5.20 upgrade from Kunena 1.5.12
Can-you put here your configuration settings ?
16 years 4 days ago #63374
by eloshy
Replied by eloshy on topic Re: Install issues on joomla 1.5.20 upgrade from Kunena 1.5.12
Yeah, which ones are you looking for?
16 years 4 days ago #63375
by xillibit
Had you installed kunena 1.6 RC3 ?
Is it possible to see your site ?
16 years 4 days ago #63376
by eloshy
I had it installed but couldn't get it to work explained above. So i uploaded by backup that I made right before i did the upgrade.
I guess I should ask, is there any issues with Jacl component.
16 years 4 days ago #63387
by Matias
Replied by Matias on topic Re: Install issues on joomla 1.5.20 upgrade from Kunena 1.5.12
I've not used Jacl.
Apache error log should reveal what the problem is -- make a copy of your site and try it in there.
Time to create page: 0.269 seconds
