Question Error migrate from Kunena 1.5.12 to Kunena 1.6
15 years 10 months ago #55625 by Mizunga
Hellow again, i find problems, i can update from Kunena 1.6 Beta 2 to Kunena 1.6 RC 1 last release, but i can't Migrate my old databases from Kunena 1.5.12 to Kunena 1.6 RC 1 i get this error:
Error on line 517 class.kunena.php
also i still having mootols problems with my template since i upgrade to Kuenna 1.6. It breaks the Javascript on my website when i enable mootols.js (System - Upgrade Mootols plugin).
any idea?
i'm using last Kunena release, and last Joomla! release.
WordPress Development and Kunena templates.
15 years 10 months ago #55628 by @quila
Hi Mizunga,
what is exactly error you have? Enable debug in joomla and refer what exactly error is.
What is Joomla version you are runing?
For joomla template we cant help you, you should update you template that support mootools1.2.
Regards
15 years 10 months ago - 15 years 10 months ago #57133 by Mizunga
Hellow, this is the message:
Fatal error: Call to a member function getAllowedCategories() on a non-object in euroviajar.com/components/com_kunena/class.kunena.php on line 517
I enable debug mode in Joomla! but i get nothing in forum page, (i think the error break all)
here is the Kunena report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Kunena version detailled: Installed version: 1.6.0-RC1 | Build: 3173 | Version name: Kujadili | Kunena detailled configuration:
Thanks in advance for your help.
Last edit: 15 years 10 months ago by Mizunga.
15 years 10 months ago #57216 by xillibit
If you choose in kunena configuration panel -> integration -> access -> kunena, what's happen now ?
The following user(s) said Thank You: Mizunga
15 years 10 months ago #57234 by Mizunga
just works, but, i loose a lot of posts.
Before update the database, i update to kunena 1.6, but not migratin, and i keep making posts, any way to recover my posts?
15 years 9 months ago #57377 by Matias
Where are your new posts? In Kunena 1.6, Kunena 1.5 or both?
If you choose to migrate again from K1.5, you will loose all new posts written in K1.6. And if you restore backup from K1.5, you will loose posts in K1.6.
Posts in K1.5 are kept as backup, but if you have something in K1.6, you need to backup it by yourself.
If you have new posts in both K1.5 and K1.6 which aren't in the another, it is hard to merge them into one database.
Time to create page: 0.277 seconds
