Question Categories are missing
15 years 2 months ago #106309 by vrillian
I had Kunena 1.6. and now i installed 1.7. Everything is ok, but categories are missing.
I see categories in forum, thats not a problem. But there are no categories in adminpanel. And there is this error message:
Warning: Invalid argument supplied for foreach() in /xxx/xxx/administrator/components/com_kunena/admin.kunena.php on line 1050
I can't create new category (example category: Sivuston artikkelit).
TableKunenaCategory::store failed - Unknown column 'accesstype' in 'field list' SQL=INSERT INTO `jos_kunena_categories` (`id`,`parent`,`name`,`locked`,`moderated`,`accesstype`,`access`,`pub_access`,`pub_recurse`,`admin_access`,`admin_recurse`,`ordering`,`review`,`allow_anonymous`,`post_anonymous`,`description`,`headerdesc`,`class_sfx`,`allow_polls`) VALUES ('','1','Sivuston artikkelit','0','0','none','2','2','1','8','1','9999','0','0','0','','','','0')
I'm confused, because last time upgrade worked fine :(
15 years 2 months ago - 15 years 2 months ago #106328 by xillibit
Replied by xillibit on topic Re: Categories are missing
Your kunena categories table seems to be broken, the structure of the table is, before use that please make a backup :
CREATE TABLE IF NOT EXISTS `lm9w8_kunena_categories` ( `id` int(11) NOT NULL AUTO_INCREMENT, `parent` int(11) DEFAULT '0', `name` tinytext, `cat_emoticon` tinyint(4) NOT NULL DEFAULT '0', `locked` tinyint(4) NOT NULL DEFAULT '0', `alert_admin` tinyint(4) NOT NULL DEFAULT '0', `moderated` tinyint(4) NOT NULL DEFAULT '1', `moderators` varchar(15) DEFAULT NULL, `accesstype` varchar(20) NOT NULL DEFAULT 'none', `access` int(11) NOT NULL DEFAULT '0', `pub_access` tinyint(4) DEFAULT '1', `pub_recurse` tinyint(4) DEFAULT '1', `admin_access` tinyint(4) DEFAULT '0', `admin_recurse` tinyint(4) DEFAULT '1', `ordering` smallint(6) NOT NULL DEFAULT '0', `future2` int(11) DEFAULT '0', `published` tinyint(4) NOT NULL DEFAULT '0', `checked_out` tinyint(4) NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `review` tinyint(4) NOT NULL DEFAULT '0', `allow_anonymous` tinyint(4) NOT NULL DEFAULT '0', `post_anonymous` tinyint(4) NOT NULL DEFAULT '0', `hits` int(11) NOT NULL DEFAULT '0', `description` text NOT NULL, `headerdesc` text NOT NULL, `class_sfx` varchar(20) NOT NULL, `allow_polls` tinyint(4) NOT NULL DEFAULT '0', `id_last_msg` int(10) NOT NULL DEFAULT '0', `numTopics` mediumint(8) NOT NULL DEFAULT '0', `numPosts` mediumint(8) NOT NULL DEFAULT '0', `time_last_msg` int(11) DEFAULT NULL, PRIMARY KEY (`id`), KEY `parent` (`parent`), KEY `published_pubaccess_id` (`published`,`pub_access`,`id`), KEY `msg_id` (`id_last_msg`), KEY `category_access` (`accesstype`,`access`) ) ENGINE=MyISAM DEFAULT CHARSET=utf8;
Last edit: 15 years 2 months ago by xillibit.
15 years 2 months ago #106415 by Matias
Replied by Matias on topic Re: Categories are missing
This will show what's wrong:
administrator/index.php?option=com_kunena&view=install&layout=schema (output the first box here)
15 years 2 months ago #107360 by mcgski
Replied by mcgski on topic Re: Categories are missing
I'm having the same problem. Ran what you suggested and got the following:
<?xml version="1.0" encoding="utf-8"?> <!DOCTYPE schema> <schema type="diff"> <table name="kunena_polls_users" action="alter"> <field name="lasttime" type="timestamp" null="0" extra="on update CURRENT_TIMESTAMP" action="alter" after="votes"/> </table> <table name="kunena_thankyou" action="alter"> <field name="time" type="timestamp" null="0" action="alter" after="targetuserid"/> </table> </schema>
15 years 2 months ago #107669 by Matias
There's nothing wrong in your database, so the issue is elsewhere. Please enable debug mode and explain what you do and what you see.
15 years 1 month ago #107957 by mcgski
Do you need me to start over or can I just enable debug mode now?
