Question Layout problems:
15 years 8 months ago - 15 years 8 months ago #89579 by makenoiz
Layout problems: was created by makenoiz
#1. Out of necessity my right column needs to be widened. Is there a way to accomplish this?
#2. Search text "Also search in child forums" displays vertical. Not sure whats happening here. Thank you for any advice.
Problem 2 only occurs in IE which I am using version 7 of
www.jvbu.com/index.php?option=com_kunena...nc=search&Itemid=144
jvbu.com
JomSocial version: 2.0.4
Joomla! version: 1.5.22
PHP version 5.2.x
MySQL version 5.0.x:
Webserver version 2.2.15
Joomla! template used: Tachyon (RocketThemes) with Gantry Framework
JomSocial template used: default
JoomXi: XIUS 2.5.358
Kunena 1.6.2
Last edit: 15 years 8 months ago by makenoiz.
15 years 8 months ago #89586 by 810
Replied by 810 on topic Re: Layout problems:
You have taken the website offline. Can you enable the site again. Thnx
regards 810
15 years 8 months ago #89588 by 810
For your other problem. Please just make one post. not more.
You are searching on the old version kunena 1.5.
Its very easy on k1.6. Go to: backend - menus - kunenamenu - And disable the options that you don't want.
regards 810
15 years 8 months ago #89594 by makenoiz
Replied by makenoiz on topic Re: Layout problems:
Yea finally a real answer... Thank you so much. Ill put site back up.
15 years 8 months ago #89595 by makenoiz
OK its back up now.... your solution to removing tabs worked great... I cant believe I searched for an hour and never found it~!
15 years 8 months ago #89596 by 810
still offline.
