Kunena 7.0.8 Released
Question [SOLVED] Gavick template causes problem with pagination in FF, Chrome and Safari
15 years 6 months ago - 15 years 6 months ago #80724 by gjhvs
Hello eveyone!
I am having troubles with the pagination in the browsers F, Chrome and Safara. See the attached file.
At the top of a category the pagination is wrong: On line 1 you get the word Pagina (Page) and behind it the page number you are looking at. I want it to be just in one line, just like it is on this forum.
Something similar is wrong beyond the topic title when a topic has multiple pages.
First you get the page numbers.. and at the end the word Pagina (Page).
In IE eveything looks good, but in the other browsers it is a little messed up.
I have tried almost everything (using FireBug) but I can't make it. Can someone help me?
Kind regards, GertJan
Last edit: 15 years 6 months ago by sozzled. Reason: Changed subject to reflect better the issues
15 years 6 months ago #80772 by sozzled
Do you see these problems with the Blue Eagle (default) Kunena template? :S
15 years 6 months ago #80844 by gjhvs
sozzled wrote: Do you see these problems with the Blue Eagle (default) Kunena template? :S
Yes also with the default template, see the attached file... hope you can help!
15 years 6 months ago #80901 by sozzled
Can you please do two things:
(1) Provide your K 1.6 configuration report; and
(2) Leave your site setup with the Blue Eagle (default) template running.
Thanks. This gives us an opportunity to see your website at first-hand. It's nearly impossible for us to remotely diagnose these problems only from a screenshot.
15 years 6 months ago #80938 by gjhvs
Got it running in the Blue eagle template at www.madonna.nl/site/forum.html .
This is the configuration report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 5M
Joomla default template details : gk_party_freak | author: Robert Gavick - GavickPro | version: 2.0.10 | creationdate: 20/03/2010
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.6.288) | UddeIm: Disabled or not installed
15 years 6 months ago #80943 by sozzled
So, you have no problems with pagination in FF, Chrome and Safari if you use the Blue Eagle template. Is that what you are saying? :dry:
Time to create page: 0.290 seconds
