Question Reply buttons not visible in message screen
15 years 10 months ago - 15 years 10 months ago #79867 by Gewitty
I just installed Kunena 1.6.2 on a Joomla 1.5.20 site. Everything seems to be woking OK, but when I view a message post, the Quick Reply, Reply, Quote and Edit buttons are almost completely hidden under the bottom line of the message panel (see attached screenshot below).
I tried adjusting the height and width parameters of the layout, but this had no effect at all. I also tried using a couple of different Kunena templates, which also made no difference.
Can anyone suggest what the problem is?
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 88888888ximum number of files that can be uploaded via a single request
Joomla default template details : js_optimus | author: Casey Lee | version: 1.1 | creationdate: 10/01/08
Kunena default template details : Euro-Green | author: Mizunga | version: 1.6.1 | creationdate: 2010-12-20
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Last edit: 15 years 10 months ago by Gewitty. Reason: Removal of confidential information
15 years 10 months ago #79878 by xillibit
Can-you look with firebug (firefox extension) if you can see something ?
15 years 10 months ago #79884 by Gewitty
Interesting. I just checked using both Google Chrome and Firefox and the problem does not occur. It's only happening in IE 8.
15 years 10 months ago #79951 by sozzled
Please contact the developer of the Kunena template that you are using and advise him of the problem that you are having. Thank you. :)
15 years 10 months ago #79985 by Gewitty
I did few more tests and found that the problem exists with templates from other developers, including Blue Eagle from the Kunena team, so it appears to be either an IE8 problem or a Kunena bug.
15 years 10 months ago #79988 by sozzled
Gewitty wrote: I did few more tests and found that the problem exists with templates from other developers, including Blue Eagle from the Kunena team, so it appears to be either an IE8 problem or a Kunena bug.
Are you suggesting that this problem appears when you use IE 8 to view this website - www.kunena.org - that uses the Blue Eagle template?
