Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question Forum gets positioned below menus, leaving a gap.
15 years 2 months ago #79660 by jostein
Hi.
I've installed the lates version of kunena forum, and it works great,
except that the forum component ends up leaving a huge gap between
the menu items, and the top of the forum.
I see there is a couple of post in here regarding this issue,
but I couldn't find a working solution for it.
Here's a link to my site:
www.cmfk.no/index.php?option=com_kunena&...ultmenu=95&Itemid=93
Anyone here who has had the same problem, and solved it?
Thanks in advance! :D
15 years 2 months ago - 15 years 2 months ago #79662 by jostein
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : sunshine | author: Fio | version: 1.0.4 | creationdate: 26.10.08
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Last edit: 15 years 2 months ago by jostein.
15 years 2 months ago #79667 by rich
Welcome jostein!
Try the following:
Go to the backend> Kunena> Template Manager. Then you choose your Kunena template, and click Edit CSS. From the files choose the "kunena.forum-min.css"and click again to edit CSS.
Add at the first code "float:left; (red):
#Kunena{padding:0;margin:0;line-height:1.333em;float:left;}
It should fix your problem. Please make at first a backup of your CSS.
The following user(s) said Thank You: jostein
15 years 2 months ago #79676 by jostein
Hi Rich! Thanks:) I've tried adding the code you gave
me without any results. Is there anything else I can try, that you
can think of?
Jostein
15 years 2 months ago #79690 by rich
hm.. i cannot find this code in your css with firebug or validator. Maybe is your css broken?
Please try these original css (modifiziert for yopu). Unzip this file and copy these 2 files in ..template/default/css
15 years 2 months ago #79692 by sozzled
rich was on the correct path but the solution is actually easier. :)
Edit your site template, ../templates/sunshine/css/template.css - add the following three lines to the end of that file:
#Kunena {
float: left;
Time to create page: 0.308 seconds
