Question gap between header and forum
16 years 1 month ago - 16 years 1 month ago #64393 by tomtom65
Hi Forum,
I'm sorry for asking this, please do not lynch me... :laugh:
But I've the (seems) old and older problem, that I've a gap between header-tab and forum-content...
The old hint to change the clear:both in css will NOT solve the problem, because these lines ar no longer in the actual css-file...
Could you please tell me, if there is a new resolution?
2nd problem: I'll fill out the "rules"-tab, but cannot find this one over the whole Kunena-Config...
Sorry for these newbie questions, but everyone was anytime a newbie... :blush:
Love and greetings from germany
TOM
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.9) | UddeIm: Disabled or not installed
Last edit: 16 years 1 month ago by tomtom65.
16 years 1 month ago #64400 by xillibit
tomtom65 wrote: 2nd problem: I'll fill out the "rules"-tab, but cannot find this one over the whole Kunena-Config...
This doc will help you : docs.kunena.com/index.php/How_to_create_a_rule_and_a_help_page
The following user(s) said Thank You: tomtom65
16 years 1 month ago #64431 by tomtom65
Hi xillibit,
thx for solving my problem #2... B)
works perfectly...
But has everyone a small, little hint for solving my #1, the "gap-problem"
If worth knowing: I'm using modified beez-template, but default kunena-template!
But every template I'm using, the gap-problem will be the same... *SIGH*
Thanks in advance for every hint...
TOM
16 years 1 month ago - 16 years 1 month ago #64435 by rich
Hello tomtom65,
attempts following: go in your Beez-Template .../template.css and add at the end this code:
#Kunena { float:left; }
Last edit: 16 years 1 month ago by rich.
16 years 1 month ago #64442 by tomtom65
Hi Rich,
great pity, the solution sounded good, but it doesn't work...:(
Same gap between the header tabs and the login and forum-content...
If everyone will have a look: www.in-landshut.de then click on "LA Foren" and you'll see it...
Best regards from "LA in germany"...:lol:
TOM
16 years 1 month ago - 16 years 1 month ago #64446 by rich
Sorry, change this Code from:
to:
#Kunena { float:left !important; }
Last edit: 16 years 1 month ago by rich. Reason: k in code to K
Time to create page: 0.150 seconds
