Solved [Resolved] Missing some bars from search menu
14 years 7 months ago - 14 years 6 months ago #121607 by alsthom
Hello.
One small issue I hope with the search menu. Some bars from search menu seems to be missing.
Please see at the attachment.
The excact adress is www.amnizia.org/index.php?option=com_kun...ew=search&Itemid=134
Can you give me some advice to fix this?
Last edit: 14 years 6 months ago by sozzled. Reason: Change topic icon
14 years 7 months ago #121614 by sozzled
I've never seen anything like this before.
Maybe this problem is caused by some other Joomla extension you are using? It might help if you posted your K 1.7 configuration report. The only things that I can figure out are that you are using K 1.7.2 on J! 1.5.x but I don't know anything else.
Perhaps someone else in the community has a clue.
14 years 7 months ago #121616 by alsthom
Here is my configuration.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 100M
Joomla default template details : sunshine | author: Fio | version: 1.0.5 | creationdate: 26.10.08
Third-party components: UddeIm 2.7
14 years 7 months ago #121623 by sozzled
I suggest that you try a different Joomla template. Do you have the problem if you use rhuk_milkyway, for example?
14 years 7 months ago #121625 by alsthom
I will try it, but I can't now. The forum is very crowded this time. :)
Or can I try to preview it? Hmmm I am going to check it....and I will return!
14 years 7 months ago - 14 years 7 months ago #121642 by alsthom
@sozzled that is my "issue". Thanx for the advice. I changed the template, and that bars can be clearly seen now. I have to find another full width template for my site...
Thanx once again.
Last edit: 14 years 7 months ago by alsthom.
Time to create page: 0.155 seconds
