Question Remove the forum breadcrumbs and top forum controls
14 years 10 months ago #111748 by Chrisx909
I'm using Kunena 1.7.1 on Joomla 1.7.3. Currently I'm using as template B and B (v1.7.x). I asked this already the developer, but he point me to this forum.
Is it possible to remove the red marked area?
Greetings from Germany,
Chris
14 years 10 months ago #111755 by sozzled
The first part, removing the breadcrumbs, is easy. You only to add these lines of CSS to your Joomla site template:
#Kunena .kforum-pathway { display: none;
The second part, is much harder. You have to modify the Kunena PHP source code and remove the part that displays the first occurrence of <table class="klist-actions"> ... and then you have to maintain that code from one release of Kunena to the next. Give me a little while and I'll try to find where we've answered this question before. If it was my website, I just wouldn't do it. ;)
The following user(s) said Thank You: Chrisx909
14 years 10 months ago - 14 years 10 months ago #111792 by Chrisx909
Thank you, your hack worked fine for me.
I tried also this command, but it blow of the bottem and upper part :( . I'm going to spend more time in this problem - but patience will also get disbursed :)
#Kunena .klist-actions { display: none; }
Last edit: 14 years 10 months ago by Chrisx909.
14 years 10 months ago #111801 by sozzled
Yes, I know. If you use CSS to hide the class .klist-actions then you hide both the top and the bottom row of forum controls. As I wrote, you can modify the source code but then it's your problem to maintain those changes from one release of Kunena to the next. In other words, you have to create your own Kunena template so that the changes won't be lost. In my personal opinion, the need doesn't justify the amount of effort involved.
However, if you are really set on making these changes and you accept the risks in doing so you can fiddle about with the file ../components/com_kunena/template/default/threads/latestx.php.
14 years 10 months ago #111823 by Chrisx909
I had a look into the latestx.php, but no idea, where to modify - so I will leave this point.
Great thank you for this incredible support/effort ;)
14 years 8 months ago - 14 years 8 months ago #115750 by colinwill78
I'm a complete noob but i finally worked this out.
(what i wanted, but i'm not sure it's what you wanted)
i used the following code at the bottom of my joomla template.
worked for me. easy and no need to update it (unless i change my template)
the first code did the welcome box and the second one did the klist-actions.
Try it out and let me know.
#Kunena table.kprofilebox {
display:none;
#Kunena table.klist-actions {
display:none;
I signed up here just to tell you. ;)
my forum is at www.paddocktalk.com.au/forum if you want to see it, but it still looks sh!t at the moment. still working at the basics.
Last edit: 14 years 8 months ago by colinwill78.
Time to create page: 0.260 seconds
