- Thank you received: 2
Question How to display rank images only (without text)?
- Castor-Designs
- Junior Member
15 years 1 month ago #103505
by Castor-Designs
How to display rank images only (without text)? was created by Castor-Designs
Hey there.
I'm using the rank system of Kunena. Since the rank text is already in my rank image, i don't want to display the rank title AND the rank image. I just want to display the rank IMAGE.
How does this work?
Thank you for your help.
How does this work?
15 years 1 month ago - 15 years 1 month ago #103532
Replied by sozzled on topic Re: How to display rank images only (without text)?
I can't imagine why, but here's the answer:
Add these lines to the end of your Joomla site template CSS file.
#Kunena ul.kpost-profile li.kpost-userrank-img img {
display: none;
Last edit: 15 years 1 month ago by sozzled.
- Castor-Designs
- Junior Member
15 years 1 month ago #103564
by Castor-Designs
Replied by Castor-Designs on topic Aw: Re: How to display rank images only (without text)?
Well okay that's for EVERY rang, in fact i just want it for some ranks. I mean I could also edit the template itself to not display rank text. Anyway thanks for that.sozzled wrote: I can't imagine why, but here's the answer:
Add these lines to the end of your Joomla site template CSS file.Code:#Kunena ul.kpost-profile li.kpost-userrank-img img { display: none; }
- soundlover
- Junior Member
- Thank you received: 1
15 years 1 month ago #104121
by soundlover
Replied by soundlover on topic rank text
Anyone can tell me if its possible to remove the rank text or disable it? So that you only have the uploaded rank image?
- CheechDogg
- Premium Member
15 years 1 month ago #104135
by CheechDogg
Find me on Facebook.
Replied by CheechDogg on topic Re: rank text
Soundlove,
Find the following file, components/com_kunena/template/default/view/profile.vertical.php
On line 36 look for the following:
Replace:
<?php if ($this->userranktitle) : ?>
<li class="kpost-userrank">
<?php echo $this->escape($this->userranktitle) ?>
</li>
With:
<?php echo $this->escape//($this->userranktitle) ?>
</li>
That will lave out the Rank tittle for you.
Replace:
</li>
With:
</li>
The following user(s) said Thank You: soundlover
- soundlover
- Junior Member
15 years 1 month ago #104136
by soundlover
Replied by soundlover on topic Re: rank text
Thank you very much.
It seems free things like Kunena give help while paid ones don't bother.
Time to create page: 0.255 seconds
