Question Word Wrap - truncated text
14 years 10 months ago - 14 years 10 months ago #102384 by christopherO
The text in my posts are truncated because of a problem word wrap not working correctly.
Example:
www.broadwascotheridge.co.uk/index.php/f...his-discussion-forum
Also the font size is large but I cannot find where to reduce this.
Chris
htaccess: Missing | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : greenabstract | author: Lonex.com | version: 1.6.0 | creationdate: 26/04/11
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.6.4
Modules: Kunena Latest 1.6.4 | Kunena Stats 1.6.4 | Kunena Login 1.6.4
Last edit: 14 years 10 months ago by sozzled. Reason: Reveal K 1.6 configuration report in message
14 years 10 months ago - 14 years 10 months ago #102386 by sozzled
G'day, Christopher, and welcome to Kunena.
What browser are you using when you see this problem. I did not see any problem using Firefox 5.
14 years 10 months ago #102389 by christopherO
Well, that's interesting - I use Firefox - however:
I see that it is OK in Ms Explorer and also in Google Chrome.
The issue my be that I am using Firefox 6.
Thanks very much for the rapid response
- I will give you tee well deserved feedback in Joomla.
Cheers
Chris
14 years 10 months ago #102813 by christopherO
Ah! The problem is an issue again.
I have upgraded to v7 and I now have width problems for all browsers.
I have set Configuration > Front End > Text Area Width to 300 but is still displays full width - going under the menus on the right.
I cleared the cache in the browser so don't know what to do now :unsure:
Chris
14 years 10 months ago #102883 by sozzled
Add the following 3 lines to the end of your Joomla site template CSS file:
#Kunena { min-width: none; }
14 years 10 months ago #102918 by christopherO
Sadly didn't work.
I thought it might be that the template is not v1.7 friendly but the issue exists with the templates installed with this version of Joomla. :unsure:
www.broadwas.info/
Time to create page: 0.242 seconds
