Question Quote Button - conflict with Rockettheme typography
15 years 11 months ago - 15 years 10 months ago #78468 by HRT222
If you see the attached picture, the Quote button is looking cut off. Any idea why as I have only changed the colours of the template and it was like this when I installed it?
Website: www.v8supercarsfangroup.com/2011builddev...&id=12399&Itemid=688
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 16M
Joomla default template details : rt_hybrid_j15 | author: RocketTheme, LLC | version: 1.5.4 | creationdate: November 16, 2010
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.0.2) | UddeIm: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.0.33) | Kunena Stats: Disabled or not installed | Kunena Login: Disabled or not installed
Last edit: 15 years 10 months ago by sozzled. Reason: Changed subject to reflect better the issues
15 years 11 months ago #78497 by xillibit
FYI : the module latestpost that you are using isn't compatible with kunena 1.6.0. Please disable legacy mode it's causing some issues with kunena 1.6.0.
This issue happens because there is a CSS conflict with your Joomla! template, so you to change the CSS class of the quote button.
15 years 11 months ago #78562 by HRT222
xillibit wrote: Hello,
Legacy mode disable.
How can I fix the CSS conflict by changing the class of the quote button? I am using a Rockettheme template with the Gantry framework so if am having issues with it, I am guessing others would to and is bit of a problem.
15 years 10 months ago #79090 by HRT222
Any ideas??????????
15 years 10 months ago #79101 by 810
Replied by 810 on topic Re: Werid Bug with Topic Tools
hi, Please update your gantry framework to the lasted version.
regards 810
15 years 10 months ago #79808 by madLyfe
my gantry is updated all the way and im having the same issue too..
word up!
Time to create page: 0.201 seconds
