Question Using different button sets
15 years 5 months ago - 15 years 5 months ago #96541 by crystalm28
Kunena 1.6.3
How do I change the "blue" subscribe button? And the same for the blue buttons "Thank you", "Favorite" and "Mark Topic Read"
Thank you ;)
Last edit: 15 years 5 months ago by sozzled.
15 years 5 months ago - 15 years 5 months ago #96557 by sozzled
You can define your own button sets and upload them to the folder ../components/com_kunena/template/default/media/iconsets/buttons/
You can then use the Kunena Template Manager to select the new button set. The ability to use different button sets depends on the Kunena template that you are using. The K 1.6.4 Blue Eagle template allows you to select different button sets.
There is a defect in K 1.6.3 that stops this feature. You need to upgrade to K 1.6.4 first.
