Kunena 7.0.8 Released
Question how do i change the font color and background color of main menu
15 years 6 months ago #87677 by antoniocerasuolo
how do i change the font color??? the background color?? text paddding space???
for the main menu:
Index Recent Topics New Topic No Replies My Topics Profile Rules Help Search
I want it to look nice..
Regards,
Antonio
15 years 6 months ago - 15 years 6 months ago #87681 by sozzled
The answer to this question depends on two things:
(1) Do you want to create your own Kunena template, something that you can take and use on virtually any site (but it's not very easy to do); or
(2) What colours do you have in mind and can you edit your Joomla site template CSS to make those changes?
If, as I think, you'd prefer the second of these two options, it would be helpful to see the site in question. Can you give us the URL of your site, details of the colours and the spacing that you would like to see between the menu tabs?
I assume - because I asked you to look at the sticky topics in this category - that you are not familiar with Firebug or you are unable figure out how to make these changes yourself before you asked.
Last edit: 15 years 6 months ago by sozzled.
15 years 6 months ago #87691 by antoniocerasuolo
yes the second option is what i was considering..I have notepad 2 which i beleive is just as good as firebug.. in any case I am using ie7.. i don't have firefox installed!
I want to know where i need to modify..if you do it i will not learn..
which is the .CSS file i need to modify?
where on the .CSS fille do i need to add code??
REgards,
Antonio
15 years 6 months ago #87692 by sozzled
Because you did not answer my questions (e.g. what colour, spacing, what is the URL of your site), I can only tell you that, in my opinion, you probably have to modify your Joomla site CSS ... and that's as much information I can give you until you answer my request for information. Sorry.
The following user(s) said Thank You: antoniocerasuolo
15 years 6 months ago #87700 by antoniocerasuolo
hi,
here you go:
www.iammalusacc.com/index.php?option=com...=entrypage&Itemid=96
as you can see the font color of the menu is blue i want it to be white but also i want there to be some padding space in the tab text so that the text doesnt go directly to the border of the tabs
15 years 6 months ago #87708 by antoniocerasuolo
as you can also see on that link the tabs are different sizes as well.. how can they become equal??
Time to create page: 0.280 seconds
