Question How To Disable "Kunena Custom CSS"
15 years 10 months ago #81817 by coder4life
I cannot find the file to disable Kunenas custom css. Is there a quick parameter I can set to turn it off, or where is the file stored for this particular section of css.
Id rather not use the parameter in the backend to set the headers, ect.
15 years 10 months ago #81839 by sozzled
Are you using the Blue Eagle (default) template? There is an option Blend with Joomla template - which is still a bit of an experimental feature - that applies a minimal amount of CSS to render your forum. See The Skinner Feedback Thread for more information.
15 years 10 months ago #81840 by coder4life
Yes I am. Yes I know about the skinner feature.
I am actually using the Default Blue Eagle template to find CSS properties and customizing all the colors, layout ect.
I just need to know the location of the file for Kunena's custom css. There is some coloring that is being applied Kunena headers that I cannot find where it is written. It looks like it is something being passed from the hard coded php files, or possibly from the database?
15 years 10 months ago #81843 by sozzled
15 years 10 months ago - 15 years 10 months ago #81846 by coder4life
Yes that is what I have been customizing. But this particular css piece is being creating upon loading the Joomla page. This resides from kunena, not any of my other template pieces.
(Location of the css as determined by firebug, line 20)
[code]http://mydomain/index.php?option=com_kunena&view=listcat&Itemid=486[code]
Last edit: 15 years 10 months ago by coder4life. Reason: Correction
15 years 10 months ago #81847 by @quila
coder4life wrote: Yes I am. Yes I know about the skinner feature.
For Kunena headers check in initialize.php
Regards
The following user(s) said Thank You: howardmonaress
