- Thank you received: 1
Question {loadposition XXX} in forum header description possible???
I believe the problem is that in the detailed message view, the forum header info is simply not output by Kunena.
However, there are other module positions you can leverage for that.
Got to the page you want to have your module to show and add ?tp=1 to the URL.
e.g. www.kunena.org/forum/170-k-16-templates-...iption-possible?tp=1
It will show you all module positions available on that page. Right now the one closest to what you want to do would be kunena_poll. Try publishing a copy of that module to that position and you should see your gallery on top of the message detailed view.
Hope this helps!
Can I hack this output?I believe the problem is that in the detailed message view, the forum header info is simply not output by Kunena.
This is an example link:
www.shipedia.eu/index/forum/28-carnival-cruise-lines.html
I have built a new moduleposition. I thought that would work in the detailed message view too...
www.shipedia.eu/index/forum/28-carnival-cruise-lines?tp=1
fxstein wrote:
This position would be perfect, but I want to show different gallery-categories in different kunena-categories... That´s the barrier...!Right now the one closest to what you want to do would be kunena_poll. Try publishing a copy of that module to that position and you should see your gallery on top of the message detailed view.
kunena_section_1 ... kunena_section_n, where n = number of section in a page (new in Kunena 1.6.1)
kunena_topic_1 ... kunena_topic_n, where n = number of topics in a page (new in Kunena 1.6.1)
Does it mean, that these positions can be displayed only in a special category??
Your idea of using something like a gallery to display category specific data, is new - I fully get it and like the idea. We just have not had a chance to code it so that the detailed view of a category displays that header you like.
Hopefully,
Conny
