Important kunena_bottom
  • lev
  • lev's Avatar Topic Author
  • Offline
  • Senior Member
  • Senior Member
  • Lorem Ipsum...
16 years 2 months ago - 16 years 2 months ago #60644 by lev
kunena_bottom was created by lev
There's no gap near the banner! Figure red arrow marked where!
Kunena 1.6 RC2 (Default template)
Sorry for my English.
Last edit: 16 years 2 months ago by lev.
16 years 2 months ago #60950 by severdia
Replied by severdia on topic Re: kunena_bottom
There are a number of ways to adjust that.
1. Add a module class suffix to your banner module and add the margin you want
2. Add a margin to the bottom of the stats box ( like .kfrontstats {margin-bottom:20px} )
3. Add padding around the .kunena_bottom DIV
  • lev
  • Offline
  • Senior Member
  • Senior Member
  • Lorem Ipsum...
16 years 2 months ago - 16 years 2 months ago #61328 by lev
Replied by lev on topic Re: kunena_bottom
Hi severdia,
The second way, I liked more, but unfortunately not quite understand how it all done. As the first and third, then, without a half-liter can not tell, I did not understand that change and where is your plan of action? If I knew where and what to edit, I did not ask, but instead he wrote, where and what to edit. But thanks anyway!
:woohoo:
16 years 2 months ago #61334 by sozzled
Replied by sozzled on topic Re: kunena_bottom
We suggest that you search the companion Wiki site which has a lot of information about how and where to change Cascading Style Sheets - or CSS files. There is actually a little more to learn about making changes to CSS in K 1.6 than there was in K 1.5 but again, searching through this forum will give you a lot of clues.
For those people who don't know about CSS (and who don't want to know about CSS) don't worry. It's not the end of the world. There are lots of people who do know about how to do this work for you and they can make these kinds of changes fairly quickly and relatively inexpensively.
  • lev
  • Offline
  • Senior Member
  • Senior Member
  • Lorem Ipsum...
16 years 2 months ago - 16 years 2 months ago #61395 by lev
Examining the code like no deviation
where is the code displayed incorrectly:
<div class="kunena_bottom"> <div class="moduletable"> <div class="bannergroup"> <div class="banneritem"> <a href="/component/banners/click/2.html"> <img src="../images/banners/don01.jpg" alt="" /> </a> <div class="clr"></div> </div> </div> </div> </div> <!-- closes Kunena div -->
where is the code displayed correctly:
<!-- F: List Actions Bottom --> <div class="kunena_bottom"> <div class="moduletable"> <div class="bannergroup"> <div class="banneritem"> <a href="/component/banners/click/1.html"> <img src="../images/banners/don05.jpg" alt="" /> </a> <div class="clr"></div> </div> </div> </div> </div>
As you can see a similar script and editing CSS will not improve the situation because it does not correctly display only on the main page, and not at all!
/components/com_kunena/kunena.php
// Bottom Module CKunenaTools::showModulePosition( 'kunena_bottom' );
Found also no gap in
../components/com_kunena/lib/kunena.credits.php
</tbody> </table> </div> </div> </div> <!-- Begin: Forum Jump --> <div class="kblock"> <div class="kheader"> <h2><span><?php echo JText::_('COM_KUNENA_GO_TO_CATEGORY'); ?></span></h2> </div> <div class="kcontainer"> <div class="khelprulesjump"> <?php CKunenaTools::loadTemplate('/forumjump.php') ?> </div> </div> </div> <!-- Finish: Forum Jump -->
correction using "<p></p>" for kunena.credits.php :P
<!-- Begin: Forum Jump --> <div class="kblock"> <div class="kheader"> <h2><span><?php echo JText::_('COM_KUNENA_GO_TO_CATEGORY'); ?></span></h2> </div> <div class="kcontainer"> <div class="khelprulesjump"> <?php CKunenaTools::loadTemplate('/forumjump.php') ?> </div> </div> </div> <!-- Finish: Forum Jump --> <p></p>
Note that this code "<br />" does not work, he pushes too much.
As the rules files:
/components/com_kunena/template/default/help.php
/components/com_kunena/template/default/rules.php
/components/com_kunena/template/default/search/advsearch.php
/components/com_kunena/template/default/categories/listcat.php
/components/com_kunena/template/default/threads/latestx.php
/components/com_kunena/template/default/threads/showcat.php
/components/com_kunena/template/default/profile/summary.php
/ All insertion made at the end of the script /
16 years 2 months ago #61412 by sozzled
Look at your CSS file. Please read Where is the CSS file?
