Question CSS Rules Being Overridden
I just installed Kunena 1.7.1 on my system and followed the instructions on this page to create my custom template and I made sure that my custom template is set as the default in the Template Manager. In my kunena.default.css stylesheet, I specified a new color and shape for the tabs. However, when I load the forums on the front-end, my rules are being overridden by some other rule (which seems to be coming from the default Blue Eagle template, but I am not sure).
Looking at it in Firebug, the rule that takes over seems to be coming from index.html (if I am on the forum's index page) and from newtopic.html if I am on the New Topic page. Obviously, this is some dynamically-generated CSS that's taking over, but I am not sure where to find the solution. I am running in debug mode. Would appreciate someone guiding me to the right solution (or FAQ). Thanks.
I would like to make a few general comments at this time.
The guide that you refer to is half-written (I'm sorry to say) and it presupposes that you have a strong working knowledge of Joomla and CSS in order to make it work. That's not to say that it isn't difficult to adapt any working Kunena template (like the Blue Eagle template that comes with Kunena) and the FAQ guide How do I change the colours of my template in Kunena? is appropriate in 99% of cases. Where the rough-and-ready guide is not appropriate is if you want to rearrange the placement of web elements or if you want to display other elements not handled by the Blue Eagle template. In those cases it's necessary to build your own template.
So, while these custom templates are wholly achievable, they take a bit of work and the half-written guides are the only ones that we have at the moment.
The Kunena forum is a self-help resource that relies on community support. The moderation team tries to connect people with the information that exists but we don't attempt to deal with major design issues that affect a handful of users. Those are, in the main, matters for people to deal with themselves - with the occasional prompting from us to (hopefully) point them in the right direction.
Again, as a general comment., because the Joomla template is the last piece of CSS loaded by Joomla, it tends to override just about every other piece of CSS that might be loaded by a module, component or pluging. That's why it's often best to slot your customised CSS into the Joomla template and leave Kunena untouched. That's not a hard-and-fast rule (of course), it's just a friendly tip.
This is probably due to the fact that Kunena hardcodes stylesheets based on the Blue Eagle template right into the page at run time as opposed to linking to external style sheets. Yikes! Even worse is that the Blue Eagle CSS rules are added no matter what; that is, even if the Blue Eagle template is not selected as the default template. I am extremely surprised at this static implementation, which can only limit flexibility and make customizing templates or developing new ones more complex than they need to.
Considering that template customization is one of the main things people tend to jump into right away, I hope the Kunena team is looking at a more modular and dynamic implementation for template customization in the next version.
That is not true, but it would take me a long time to explain what you need to do. I don't make custom templates myself; it takes too much time and, if I was doing that, I would not have any time to look at the questions that people ask on the forum. I just use the stock-standard, unmodified Blue Eagle template and make the occasional small adjustment to my Joomla template to accommodate colours, font styles and a few minor cosmetic things.steacha wrote: ... Blue Eagle CSS rules are added no matter what ...
I already looked at the source code to see what I would need to modify to prevent the hard-coding of the CSS rules within the head of the HTML, but I remain curious as to why you said that it's not true. Is it because custom templates built following the instructions in the guide I referred to earlier are by default being loaded as a subset of the Blue Eagle template? In other words, the Blue Eagle template is still seen as the parent template and hence why its rules are still being hard-coded even though I specified my custom template as the default one; is this the case?sozzled wrote:
That is not true, but it would take me a long time to explain what you need to do...steacha wrote: ... Blue Eagle CSS rules are added no matter what ...
- smichaelmoore
Any assistance would be greatly appreciated. The site is still under development, but you can see it here:
Knoxville Now
