Question Problems with component Xmap
15 years 9 months ago #83214 by Grandson
Fatal error: Class 'JFile' not found in /home/v/vnuk/kpecm.ru/public_html/administrator/components/com_xmap/extensions/com_kunena.php on line 157
encoding problems, tell me how to fix.
htaccess: Exists | PHP environment: Max execution time: 240 seconds | Max execution memory: 240M | Max file upload: 999M
Joomla default template details : jxtc_escene | author: JXTC | version: 1.0 | creationdate: 4/20/09
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
15 years 9 months ago #83268 by xillibit
Where do you have found the kunena xmap things ? I never used it and if i can look the file i can help you...
The following user(s) said Thank You: Grandson
15 years 9 months ago #83289 by Grandson
xillibit wrote: Hello,
Attach a file with the latest version of the component Xmap, The official site: joomla.vargas.co.cr/
15 years 9 months ago #83308 by xillibit
Add line 154, this should fix the issue :
jimport('joomla.filesystem.file');
If it's works maybe report it to xmap developpers
15 years 9 months ago #83316 by Grandson
xillibit wrote: Add line 154, this should fix the issue :
Thanks, but is it possible to detail in what kind of file it is inserted?
15 years 9 months ago #83317 by xillibit
this one : /administrator/components/com_xmap/extensions/com_kunena.php
