Question K 1.6.2 - Submit button does not work for guests
15 years 10 months ago - 15 years 10 months ago #80079 by phal
I am using Kuena 1.6.2 with Joomla 1.5.22 and mootools upgrade plugin enabled and jomsocial integration with sh404sef installed but turned off
There is no response in clicking the submit button for anonymous users when using firefox 3.6.13
The same button work in I.E. when anonymous
The same button work after user has login, even in firefox 3.6.13
Regards
Last edit: 15 years 10 months ago by sozzled. Reason: Changed subject to reflect better the issues
The topic has been locked.
15 years 10 months ago - 15 years 10 months ago #80143 by sozzled
I haven't had time to test this particular issue on a site with J! 1.5.22 and K 1.6.2 and so I'm unsure whether sh404SEF is still responsible for the problem even with the claim that you have it "turned off". So, I tried an experiment on a test site where I have a category setup for anonymous posting: K 1.6.2 (build 3894), Joomla 1.5.22, Firefox 3.6.12 (but without sh404SEF) and I had no problems at all.
So, my test doesn't necessarily prove anything except to disprove the general claim that "anonymous submit button does not work in Firefox". I agree that it may not work for phal but I don't know what else this person has running on their website.
Perhaps this isn't a Kunena problem at all. Perhaps this is a template issue. My test site uses JA_Purity - the standard one that comes with Joomla. What does your site use?
15 years 10 months ago #80157 by sozzled
Apparently this could be a genuine problem. After further testing it seems that the Submit button is non-operational only for users who are not logged-in to the website.
Registered users can post anonymously but only if they are logged-in. I will need to report this to the development team for an answer.
15 years 10 months ago #80161 by phal
Dear Developer,
I have tested it on several scenarios including a fresh install of joomla and kuena only, the problem still persists.
I love the functionality of Kuena, especially it has anonymous posts... I hope it can be fixed soon
Regards
15 years 10 months ago #80208 by roydepp
Same issue here.
K1.6.2 J! 1.5.22. Nothing happens when a guest user (not logged in) clicks the "Submit" button via Firefox (test v. 3.6.13), Works ok with IE8.
15 years 10 months ago #80433 by sultani
After i made de update from kunena 1.6.1 to 1.6.2 the submit button stop worked for guest posts.
Here is my configs:
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 900 seconds | Max execution memory: 64M | Max file upload: 350M
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
Kunena default template details : Euro-Orange | author: Mizunga | version: 1.6.0 | creationdate: 2010-08-010
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Installed (Version : 1.5.12) | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Enabled (Version : 1.6.2) | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Disabled or not installed | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
Anyone with the same issue?
Regards
Time to create page: 0.152 seconds
