Question upload problem
15 years 11 months ago - 15 years 11 months ago #77878 by xenofonpro
upload problem was created by xenofonpro
hello...i'm new in the community and i am from greece so sorry about my english.i have a problem when i try to upload an attachments file to a new topic.when i try to upload a zip,rar or a docx file I click add, i can pick the file and the, the file gets submitted.but i cant see it nowhere.and at the configuration menu i can't see this type of files.at the attachment file is the picture with the settings i did at the cofiguration menu.please help me.
thank you
Last edit: 15 years 11 months ago by xenofonpro.
15 years 11 months ago #77881 by xillibit
Replied by xillibit on topic Re: upload problem
Can-you put here please your kunena configuration report settings ?
15 years 11 months ago #77882 by xenofonpro
Replied by xenofonpro on topic Re: upload problem
thanks a lot for your quick reply:) this is the configuration report.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : reddigit | author: | version: 1.0 | creationdate: 2010-12-13
15 years 11 months ago #77904 by xillibit
Your configuration seems correct, but IIS 6.0 can causing issues maybe
Do you have a test account on your site like that i can test ?
15 years 11 months ago - 15 years 11 months ago #77959 by xenofonpro
if i understand well, you want an acount to login at the forum???you can login with username:user and pass:user at this section of the forum www.e-digit.gr/myjoomla/index.php?option...at&catid=50&Itemid=5 ] and do the test you want.what is IIS 6.0??can i do any to correct my problem??thank you.
15 years 11 months ago #78081 by Dohtur
Replied by Dohtur on topic Re: upload problem
I also have problems - does not download the files in the forum.
test.zip - not found
Found no solution to this problem
File permissions are correct, but on the local machine does not work, and in the right Windows (local) files do not play a role
