Question Ordering system
16 years 1 month ago #67664 by Alhazred
Ordering system was created by Alhazred
I've installed Kunena, it order the messages according to their message id, I want them sorted by date and time. How can I do that?
I've seen inside kunena.config.class.php the variable var $ordering_system = 'mesid'; and the value mesid inside the jos_kunena_config table.
Do I have to change them? What should I write there? I haven't seen any option on Kunena's control panel.
16 years 1 month ago - 16 years 1 month ago #67682 by Alhazred
Replied by Alhazred on topic Re: Ordering system
I missed to say that I migrated from phpBB3 (where the posts where shown correctly) to Kunena, I've tried both passing through Fireboard 1.0.4 and straight to Kunena 1.6 with the same result.
The problem doesn't look to be exactly as I said in the 1st post, I make an example.
I have a topic with 5 posts in it, if I order it with "asc" method I have the posts shown in this way:
date and time: 09/26/2010 5:05pm
date and time: 09/26/2010 7:52pm
date and time: 09/26/2010 9:06pm
date and time: 09/26/2010 9:48pm
date and time: 09/26/2010 11:47am <-- this is the opening post
If I set "desc" order I see this:
As you can see is the opening post which is not placed correctly, how to fix this?
Last edit: 16 years 1 month ago by Alhazred.
16 years 1 month ago #67685 by haithun
Replied by haithun on topic Re: Ordering system
How did you migrate? I don't know how to do it so you have o tell me.
If it is a PHP script or a SQL statement you only have to go into it and change the order to "desc".
16 years 1 month ago #67688 by Alhazred
I've used the converter suggested here
docs.kunena.com/index.php/PHPBB3_to_Kunena
The only "asc" sort in it is about Groups' id, not for posts.
16 years 1 month ago - 16 years 1 month ago #67695 by haithun
Well there is an ASC for the post but its not written due to the fact that ASC is the default.
change the line
$query="SELECT p.post_id, p.poster_ip, p.topic_id, p.poster_id, p.post_time, ". "p.post_username, t.topic_title, t.forum_id, t.topic_views, p.post_subject". " FROM `$phpbb_db`.`{$phpbb_dbprefix}posts` AS p, ". "`$phpbb_db`.`{$phpbb_dbprefix}topics` AS t ". " WHERE p.topic_id = t.topic_id ". // $JMI " ORDER BY p.topic_id, p.post_id";
to
$query="SELECT p.post_id, p.poster_ip, p.topic_id, p.poster_id, p.post_time, ". "p.post_username, t.topic_title, t.forum_id, t.topic_views, p.post_subject". " FROM `$phpbb_db`.`{$phpbb_dbprefix}posts` AS p, ". "`$phpbb_db`.`{$phpbb_dbprefix}topics` AS t ". " WHERE p.topic_id = t.topic_id ". // $JMI " ORDER BY p.topic_id, p.post_id DESC";
This should turn around the posts processing.
Last edit: 16 years 1 month ago by haithun.
16 years 1 month ago #67700 by Alhazred
Thanks, but that didnt help.
It looks that the posts are sorted using their ID, not their timestamp.
If you have a clean installation everithing works also if you sort by messages' ID, but if you come from another forum when you import posts they can have their ID altered.
Does Kunena sorts posts only in that way? Is it possible to change this method?
