Question problem with statistics
The error is in the Top 5 Most Thank You's
Warning: Invalid argument supplied for foreach() in
../components/com_kunena/template/default/plugin/stats/stats.php on line 285
What could be causing this?
I'm using 1.6
You have posted your question in the Support category but, as we have no way of knowing what you have referred to, you have not given us any details about your configuration. It pays to read the hints given in the category description:
Does your question relate to the Kunena component or the Kunena Stats module (which is something else, separately downloadable from this website)? In other words, are we discussing K 1.6.0 or are we discussing mod_kunenastats1.6.0RC2?This category is for Kunena version 1.6 issues only. For a faster response, please make sure you include your Kunena 1.6 configuration settings report in your posts. We do NOT support alpha or beta test versions. Before asking for support, please read the guides posted as sticky topics in this category.
Until K 1.6 becomes a stable release, we can only give limited support.
Questions asked in the Support category have the highest priority. This is particularly true when there are new releases of Kunena and we want to make sure that there isn't some defect in the software that is lying in wait to ambush the users. In spite of the best care and rigorous testing carried out by the development/testing teams some errors still filter through.
I think yours is the first time that we have seen this problem you've mentioned; yours is an unusual case because the statistics areas are things that users often check very early after they've installed Kunena (or so I would imagine). Perhaps yours is an isolated case? Whatever the circumstances, there's no way of knowing what's happening, or knowing how to help you, without seeing your configuration report.
I think it's a known issue, can-you please put a link to your more statistics page ?
"Warning: Invalid argument supplied for foreach() in ../components/com_kunena/template/default/plugin/stats/stats.php on line 285"
into google you will see many pages that updated to 1.6 and same thing happens
Greetings
