Question [Template Menu Code BUG] Problem with Joomla Core SEF and RC3
16 years 2 months ago - 16 years 2 months ago #62123 by roland76
all links don't work on my site. I just upgraded from 1.5.12 to RC3.
see www.simple-quality.de/forum
edit by fxstein: Root cause is template menu module bug - in this case JoomlArt JA_Vauxite see here: www.kunena.com/forum/168-k-16-support/62...re-sef-and-rc3#62177
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 72M | Max file upload: 24M
Kunena version detailled: Installed version: 1.6.0-RC3 | Build: 3539 | Version name: Jadili | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Installed (Version : 1.5.9) | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.0)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed
Last edit: 16 years 2 months ago by fxstein.
16 years 2 months ago #62126 by roland76
Ok, found the problem...
This comes from my menuestructure...
I nested the menue by hand under my main menue... And this seems not working...
16 years 2 months ago #62129 by fxstein
My guess this could be a menu setup issue. The menu systems drives most of the SEF behaviour.
Do you have examples you can share?
16 years 2 months ago #62131 by roland76
Mhh - I always have problems with the SEF...
If i click on a topic / thread the menue is away...
16 years 2 months ago #62133 by roland76
www.simple-quality.de/forum.html
and then click on a thread / post and the menue is away...
16 years 2 months ago #62134 by fxstein
Recreate the Kunena Menu. That way all manual changes get corrected.
