Question conversion tool for converted agora to Kunena 1.6
15 years 8 months ago #57767 by Armored Warriors
how i converter agora forum to kunena 1.6??
I hope it's an easy thing to do it!
i use Joomla! 1.5.19 Stable
Version PHP: 5.2.13
database Version : 4.1.22-standard-log
Thanks in advance for your help
15 years 8 months ago - 15 years 8 months ago #57785 by Cerberus
********** ALWAYS TAKE A BACKUP OF SITE AND DATABASE BEFORE RUNNING ANY SCRIPTS **********
Here we have a script to convert Agora to Kunena, there are 2 versions one for K1.5 and one for K1.6, make sure you select the right version for your needs.
Here’s what you’d need for these scripts to be useful for your install too:
•Existing Categories in your Kunena db that mirror the old Agora forums
•Command Line Access to your server
•Basic understanding of SQL and shell scripting
Here’s what the scripts does:
•Works with or without CB
•Import all posts from Agora to Kunena
•Convert agora user ids to joomla ids (used by Kunena)
•Updates post counts by category
Here’s what to do:
1. Make sure your categories are set up
2. Download the zip file BELOW
3. Upload to your site web root directory (public_html) via FTP
4. Open configure.php
5. Modify the connection info at the top
6. Set the agora forum ids to kunena category ids
7. Set $fake_inserts = true
8. Run the script: www.YOURDOMAIN.com/convertor/converter.php (a test run)
9. Check out the printed results and make sure they look sensible ( if unsure ASK at this stage )
10. Set $fake_inserts = false
11. Have a go at the real data (you have a backup, right?? cause this can only be done once )
Here is the K1.5 script:
Download Here (KED)
Here is the K1.6 script:
Download Here (KED)
All credits for this script go to Zentrack
Last edit: 15 years 8 months ago by Cerberus.
The following user(s) said Thank You: fxstein, @quila, Armored Warriors
15 years 8 months ago #57799 by Armored Warriors
ok tomorrow I'll try this converter
I hope all is well!
and thanks for your help
15 years 8 months ago #57909 by Cerberus
any news on this did it work for you armored warriors???
15 years 8 months ago #57932 by Armored Warriors
I'm trying it on the local site
15 years 8 months ago - 15 years 8 months ago #57933 by Cerberus
cool thanks can you let me know how it goes please :)
Time to create page: 0.632 seconds
